Re: fluctuating fuel pressure
[Re: SV_MOPARS]
#1226699
05/03/12 04:12 PM
05/03/12 04:12 PM
Posts: 1,532 off the grid
340B5
off the grid
The pressure will drop on the guage when the liquid heats up. Also the return line needs to be bigger than the feed line.
Yeah, it's got a smallblock.
[Re: 340B5]
#1226701
05/03/12 04:20 PM
05/03/12 04:20 PM
A57_RT
Parts Problem
Parts Problem
Are you running a constant voltage to your FP???
I should of said consistant voltage.
[Re: A57_RT ]
#1226703
05/03/12 09:07 PM
05/03/12 09:07 PM
Posts: 1,236 Fairview Tennessee
SV_MOPARS
Fairview Tennessee
as far as i know it is getting consistant voltage, its on a relay, i will have to check, i think i will start with the gauge, somebody did mention that the return should be the size of the feed or bigger,i'm not doubting that, but i just can't see it creating that much of a fluctuation.
[Re: Moparnut426]
#1226705
05/03/12 11:21 PM
05/03/12 11:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Never heard of that, I thought an autometer guage thats liquid filled is about the most accurate style of guage there was?? I would think they might want to use a non expanding form of liquid. But that might be why they are not filled all the way to allow for the expansion.
Lear something every day I guess.
Liquid filled gauges are great in a constant temp environment but when the oil in them heats up it pushes back on the measuring tube inside the gauge... normally with the filled gauges they show a lower pressure than whats really there(in a under hood environment)with increasing temps..... to the OP... drain the gauge first... there is a rubber plug on the top... pull it and let it drain out.. either leave the plug out or put a small hole in the plug so it can vent ... then check your system again
[Re: SV_MOPARS]
#1226707
05/04/12 01:37 AM
05/04/12 01:37 AM
MR_P_BODY
thanks for that info mr p body, i was hoping you would chime in, you always seem to have a good answer or response.
No problem... my buddy had the same issue on drag week 2 years ago(pressure was dropping according to his filled gauge) but he didnt believe it was the gauge so when he went to check out one of the cars I drained it and just left the plug out... when he got back I told him I found the problem and fixed it... so when he fired it up then looked at the gauge it was fine and he asked what I did... I told him... he still didnt believe me.... LOL
[Re: SV_MOPARS]
#1226709
05/06/12 12:02 AM
05/06/12 12:02 AM
MR_P_BODY
drained the fuel pressure gauge and readjusted the regulator, took the car out for a few more shake down miles and it seams to be holding at 6 1/2 lbs, hopefully she will hold , thanks for the input.
Glad you got it squared away
