Page 4 of 4 1 2 3 4
Re: Running hot and running out of ideas 67 Belvedere [Re: BigBlockMopar] #1226319
05/05/12 03:18 PM
05/05/12 03:18 PM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
It degreed within .5 of a degree.
If I remember correctly it was made by Modine, the core is roughly 3" wide, using a cast factory 6 blade water pump. The radiator only has 3400 miles on it and less than 1000 with the new stroker.
Re: Running hot and running out of ideas 67 Belvedere [Re: feets] #1226320
05/05/12 03:28 PM
05/05/12 03:28 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
He verified that his radiator is doing it's job. There's no need to look at replacing it.
He needs to find the source of the heat.
A loose converter dumping trans heat into the radiator or blown head gasket would easily cause that problem.
I wasn’t suggesting he replace his radiator. I know he said he had good a temperature drop cross the radiator. I was just relating a similar experience with my car hoping it would help him out. I also had a 30 degree plus drop across the radiator but it still wouldn’t cool. When I installed the new radiator and electric fan I left everything else the same. I am convinced even though the three core radiators fin design was inferior installing the electric fan is what cured my cooling problem.
Re: Running hot and running out of ideas 67 Belvedere [Re: Dabee] #1226321
05/05/12 06:07 PM
05/05/12 06:07 PM
mass,usa
sickhemi Offline
sickhemi  Offline
mass,usa
did you paint the radiator?
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
Re: Running hot and running out of ideas 67 Belvedere [Re: sickhemi] #1226322
05/05/12 06:12 PM
05/05/12 06:12 PM
Phoenix, AZ
Phoenix, AZ
I didn't but it was painted by the radiator shop that cleaned it. Its not a thick layer that would block airflow.
Re: Running hot and running out of ideas 67 Belvedere [Re: Challenger 1] #1226323
05/05/12 06:42 PM
05/05/12 06:42 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Can you turn the clutch fan by hand with the engine hot? There should be ALOT of resistance.
This is a very real possibilty, it happened to me. New fan clutch and it was back to normal.
Good luck with it.
I'm betting it a at least a couple factors, not just one.
I've seen a bad fan clutch cause overheating before too, so that's another possibility. A guy came into my Dad's gas station with a Chrysler that was overheating. The fan was barely turning while the engine was running.
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226324
05/05/12 06:48 PM
05/05/12 06:48 PM
mass,usa
sickhemi Offline
sickhemi  Offline
mass,usa
do you have headers on the car and are they uncoated. if the car is running lean at idle it the headers will get real hot
Re: Running hot and running out of ideas 67 Belvedere [Re: sickhemi] #1226325
05/05/12 09:21 PM
05/05/12 09:21 PM
Phoenix, AZ
Phoenix, AZ
The fan is spinning really well.
The headers are ceramic coated, its not running lean for sure. I would have to check my book but I beleive it has the largest jets and richest rods from the strip kit.
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226326
05/05/12 11:24 PM
05/05/12 11:24 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
You can't tell with the engine running, you need to get the engine hot, shut it off, then spin the fan by hand. There should be alot of resistance.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Running hot and running out of ideas 67 Belvedere [Re: DARTH V8Я] #1226327
06/14/12 01:12 AM
06/14/12 01:12 AM
Phoenix, AZ
Phoenix, AZ
Update: Went for a ride last night and pulled in the driveway with the temp @ 220, shut the car off and spun the fan with absolutely no resistance at all. Looks like the new fan clutch is no good.
Re: Running hot and running out of ideas 67 Belvedere [Re: DARTH V8Я] #1226328
06/14/12 06:55 AM
06/14/12 06:55 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
A few years ago my neighbors ferd pickup had a heating problem, when I opened the hood I noticed that the fan was on wrong, it could not pull the air properly. Once the fan blades were on properly the heating problem disappeared.
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226329
06/14/12 07:39 AM
06/14/12 07:39 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Looks like you found the problem. Let us know how it turned out after you get it replaced.
Re: Running hot and running out of ideas 67 Belvedere [Re: 6PakBee] #1226330
06/14/12 07:49 AM
06/14/12 07:49 AM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Hi, here is a write-up I did on my 383 cooling issues. You mentioned you are using the 6-vane pump, you might want to get the 8 vane version.
The 6-van is used with an A/C car with a smaller pully, which spins the pump harder. The 8-vane pump is used with a slightly larger pulley on a non-A/C car. Which pulleys are you running?
You problem to me sounds either coolant flow related or more likely airflow related (especially considering your clutch fan is not doing the job).
This thread is now "archive status", which means no pics, which sucks... if you want the pics of the pump I can dig them up.
http://www.bigblockdart.com/forum/archive/index.php/t-20229.html
383, Hemi 4-Speed, AlterKtion, D60
Re: Running hot and running out of ideas 67 Belvedere [Re: Crazy68Dart] #1226331
06/14/12 07:59 AM
06/14/12 07:59 AM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Re: Running hot and running out of ideas 67 Belvedere [Re: Dabee] #1226332
06/14/12 09:18 AM
06/14/12 09:18 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
right. a radiator could be partially blocked, or restricted, you'll still have some flow, which means you'll still get a nice even temperature drop across the radiator and no sudden cool spots, but the overall GPM flow of the entire system won't be up where it should be.
regardless, it sounds like he found the problem when he discovered that his fan clutch has no resistant and free spins when the engine is hot.
**Photobucket sucks**
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226333
06/14/12 01:27 PM
06/14/12 01:27 PM
organ
maximum entropy Offline
organ
fan clutches are extremely reliable, and blamed for a lot of problems that are actually caused by other things. if your radiator is plugged in the center, the fan clutch won't get hot enough to engage. i have seen this MANY times over the years.
Re: Running hot and running out of ideas 67 Belvedere [Re: maximum entropy] #1226334
06/14/12 10:17 PM
06/14/12 10:17 PM
Phoenix, AZ
Phoenix, AZ
Just how much resistance should I be getting when trying to spin the fan? I can spin it around several times with just a flip of my index finger.
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226335
06/14/12 11:46 PM
06/14/12 11:46 PM
Batavia,Ohio,
Moparmick Offline
Moparmick  Offline
Batavia,Ohio,
Ok I read all the posts here and no one has mentioned this, Check your grounds make sure they are clean and tight a bad ground can cause overheating, if ground is not good your electrical system will look for the next best source for ground which could be cooling system, I know because this happened to me.
Re: Running hot and running out of ideas 67 Belvedere [Re: Moparmick] #1226336
06/15/12 12:04 AM
06/15/12 12:04 AM
Phoenix, AZ
Phoenix, AZ
I'll give it another look but last check they were all tight.
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226337
06/15/12 01:26 AM
06/15/12 01:26 AM
organ
organ
THE BEST way to test a fan clutch is to listen for engagement. it should be obvious. if it's not getting hot enough at idle to engage the clutch, try putting a piece of cardboard in front of the radiator. the temperature the clutch engages at will vary depending on type/ brand/ application, but it should engage with authority. you should hear the unmistakeable roar of the fan, and feel the airflow increase dramatically. if you don't, it might be a plugged radiator as i mentioned earlier. i wish i had a penny for every time i heard a customer tell me, "i've replaced the fan clutch 4 times, and it still gets hot!"
Page 4 of 4 1 2 3 4
