Re: best distributor to use with mopar ecm (orange box)
[Re: Dunnuck Racing]
#1226225
05/02/12 09:55 PM
05/02/12 09:55 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
The only problem I have seen with the MP units is hi RPM stability goes out the window. The way the pick up coil is mounted in them is a joke. Keith
he won't be doing very much high RPM stuff running an orange box.
[Re: Slipknot440]
#1226226
05/02/12 10:09 PM
05/02/12 10:09 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
I really don't want to get rid of the stock electroic ignition now that efi is running well but I would like a better distributor that I can use with stock ecm. Recomendations?
First off the orange box was never stock on anything and you are giving up top end HP because it retards the timing above 4000 rpm . I'd be changing it to something BETTER.
What distributor do you currently have ?
[Re: Slipknot440]
#1226228
05/02/12 10:49 PM
05/02/12 10:49 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
From reading posts here I'd say the best distributor to run with an MP orange box is a points distributor, that way the MP box won't fail.
[Re: Supercuda]
#1226229
05/02/12 10:49 PM
05/02/12 10:49 PM
JohnRR
holy bleep , I actually agree with you on this one ... ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: pjc360]
#1226234
05/03/12 12:24 AM
05/03/12 12:24 AM
JohnRR
Screw points get the newer mopar distributer they are made by mallory and have an adjustable mechanical advance and they are relatively cheap too. You'd be spending about 200 bucks and they are nice distributers. Any MP distributer built after 2004 will be the newer MP distributer with an adjustable mechanical advance. You wont be disapointed with it.
They still have the crappy breaker plate design of the old distributors.
[Re: pjc360]
#1226236
05/03/12 01:23 AM
05/03/12 01:23 AM
JohnRR
yes but for 200 bucks you couldnt ask for a better factory distributer in my opinion. The fact that mopar finally made a distributer with an adjustable mechanical advance is awesome. And the spring kit from mopar is fourty bucks. I was more then happy with mine.
Don't get me wrong , I have them and use them but they are not the greatest thing since sliced bread you make them out to be .
