Exhaust Manifolds #1226109
05/02/12 06:38 PM
05/02/12 06:38 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
How big a tap/plug do I need to properly plug the hole in the aft ends of stock 318 manifolds (the one that the air pump plugs in to)?
Re: Exhaust Manifolds [Re: jeebis44] #1226110
05/03/12 01:19 AM
05/03/12 01:19 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
You can use a small freeze plug or make a block off plate and bolt it on.No need to tap threads.I will try to get the freeze plug size tomorrow.RT
