Re: Side stripe install, are older stripes more difficult?
[Re: NV69B7RR]
#1226085
05/02/12 06:18 PM
05/02/12 06:18 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Whenever I done stripes/decals that were rather thin on film thickness, micro airbubbles were always bothersome, don't be tempted to pinprick them to bleed them out, and avoid excessive pressure trying to squeege them out as that will wrinkle and tear the film,....just do the best you can, make sure to use filtered or bottled water for your water supply, you'd be surprised at the debri in city/well water(this could be your problem too?, debri to small to see, but visible under the film) either set the car out in the sun for a few days, or carefully use a heatgun to shrink the decal, this will remove micro airbubbles, if that's all they are?, if your water was contaminated with debri, then it's never going away...
[Re: Kern Dog]
#1226088
05/03/12 02:32 AM
05/03/12 02:32 AM
Posts: 523 Right here
HP2
Right here
Take the car outside and let the sun do the job. Be patient and if you are lucky the mist will evaporate and the decal will level out. That is the best you can do now. If it wont work after a week or so you will have to peel it off and get new stickers... Good luck!
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
[Re: HP2]
#1226089
05/03/12 09:53 AM
05/03/12 09:53 AM
Posts: 2,143 Port Saint Lucie, FL
ChallengerGary
The vinyl is not truly solid, it is slightly porous and the moisture should evaporate after some time in the sun. How long it takes really depends on where you live and how strong the sun is there.
