Chrome Box EIM - Does it Retard Advance? #1225994
05/02/12 02:33 PM
05/02/12 02:33 PM
MassHole Central
rtman Offline OP
rtman  Offline OP
MassHole Central
Like the Orange box does at 4000RPM?
And, does anyone have a schematic of both the Orange and Chrome boxes? It has become an unfunded engineering project at my work
And any reference to MSD will be ignored...except someone who has an MSD that fits the stock loom
Re: Chrome Box EIM - Does it Retard Advance? [Re: rtman] #1225995
05/02/12 04:20 PM
05/02/12 04:20 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Re: Chrome Box EIM - Does it Retard Advance? [Re: JohnRR] #1225996
05/02/12 05:28 PM
05/02/12 05:28 PM
MassHole Central
rtman Offline OP
rtman  Offline OP
MassHole Central
But, JRR, its a simple question that I have to imagine someone has the answer to...
Re: Chrome Box EIM - Does it Retard Advance? [Re: rtman] #1225997
05/02/12 05:40 PM
05/02/12 05:40 PM
U.S.S.A.
U.S.S.A.
The was for your what you edited out ...
I'll pm the rest of my response not to derail your question.
Re: Chrome Box EIM - Does it Retard Advance? [Re: rtman] #1225998
05/02/12 08:44 PM
05/02/12 08:44 PM
organ
maximum entropy Offline
organ
my orange and chrome boxes must be aberrations.
Re: Chrome Box EIM - Does it Retard Advance? [Re: rtman] #1225999
05/02/12 08:51 PM
05/02/12 08:51 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
What do you want as far as a schematic? They are wired the same. Both boxes have the same dwell/spark retard.At least the two orange and one chrome that I have dyno tested with do.
Keith
Re: Chrome Box EIM - Does it Retard Advance? [Re: maximum entropy] #1226000
05/02/12 10:16 PM
05/02/12 10:16 PM
U.S.S.A.
U.S.S.A.
Care to expand on that ?
His orange box was on a chassis dyno last friday , connected to it and it showed the timing retard above 4000 rpm.
Keith are you saying the chrome box also pulls out timing above 4000 rpm ?
Re: Chrome Box EIM - Does it Retard Advance? [Re: JohnRR] #1226001
05/02/12 10:32 PM
05/02/12 10:32 PM
Northern Indiana
Northern Indiana
Mine does. Both boxes had identicle dwell and timing curves through 6500 rpm which is as high as I tested them.
Re: Chrome Box EIM - Does it Retard Advance? [Re: JohnRR] #1226002
05/02/12 10:34 PM
05/02/12 10:34 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
from my experience with the ecu boxes most will reduce dwell some as the rpm increases. not sure if that will retard timing. the timing retard that i have experienced as rpm increased was mechanical related, not electrical.
Re: Chrome Box EIM - Does it Retard Advance? [Re: lewtot184] #1226003
05/02/12 10:37 PM
05/02/12 10:37 PM
U.S.S.A.
U.S.S.A.
How would centrifugal force acting on the weights retard the timing ?
Re: Chrome Box EIM - Does it Retard Advance? [Re: JohnRR] #1226004
05/02/12 10:40 PM
05/02/12 10:40 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
my problem wasn't ignition related. timing chain with a little cam walk.
Re: Chrome Box EIM - Does it Retard Advance? [Re: lewtot184] #1226005
05/02/12 10:41 PM
05/02/12 10:41 PM
U.S.S.A.
U.S.S.A.
Everything on the engine in question is brand spanking new .
Re: Chrome Box EIM - Does it Retard Advance? [Re: lewtot184] #1226006
05/02/12 10:43 PM
05/02/12 10:43 PM
Northern Indiana
Northern Indiana
Dwell ddirectly affects timing,.
Re: Chrome Box EIM - Does it Retard Advance? [Re: JohnRR] #1226007
05/02/12 10:51 PM
05/02/12 10:51 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
my timing chain was brand spankin' new too. just relating an experience, believe what you want.
Re: Chrome Box EIM - Does it Retard Advance? [Re: rtman] #1226008
05/03/12 09:30 PM
05/03/12 09:30 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
How much timing retard are we talking about here?
Re: Chrome Box EIM - Does it Retard Advance? [Re: forphorty] #1226009
05/04/12 12:11 PM
05/04/12 12:11 PM
MassHole Central
rtman Offline OP
rtman  Offline OP
MassHole Central
about 10 degrees dropping off at 4000-4200rpm
Re: Chrome Box EIM - Does it Retard Advance? [Re: Dunnuck Racing] #1226010
05/04/12 03:18 PM
05/04/12 03:18 PM
organ
organ
not if the dwell starts earlier. it can be manipulated electronically. i've checked several orange boxes, and one chrome box, to 6000 rpm- no sign of retardation (pardon the choice of words). they are all old boxes, though. i think my newest one is over ten years old. i think ballast resistor selection is important, too. iirc, there are two resistance values available? i have always used the higher resistance, and have had no ignition issues ever (aside from a ballast resistor failing at an extremely inopportune time).
Re: Chrome Box EIM - Does it Retard Advance? [Re: maximum entropy] #1226011
05/04/12 03:25 PM
05/04/12 03:25 PM
U.S.S.A.
U.S.S.A.
In the other thread about this subject it is claimed that there was a change made to them in 2000. So if your boxes are older than that it doesn't help with this question/problem.
But thanks anyway.
Re: Chrome Box EIM - Does it Retard Advance? [Re: JohnRR] #1226012
05/04/12 04:28 PM
05/04/12 04:28 PM
organ
organ
But thanks anyway.
you're welcome.
Re: Chrome Box EIM - Does it Retard Advance? [Re: maximum entropy] #1226013
05/05/12 10:57 AM
05/05/12 10:57 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I have a Sun distributor machine. When I first got it I thought I wasn't using it properly or that there was something wrong with it. The timing would reach full advance at whatever rpm and then at high rpm it would loose a few degrees at max rpm. Talking with other distributor machine owners, they have found the same trends. I'd still like to hear a explanation for why this happens. You would think centrifugal forces wouldn't allow it
That said I don't think I have ever seen 10 degrees only a few.
