1968 Charger Front Hub? #1225950
05/02/12 11:28 AM
05/02/12 11:28 AM
Kansas
monacoman Offline OP
Kansas
Does anyone sell the front hubs for a 68 Charger with 11 inch brake drums? Thanks.
Re: 1968 Charger Front Hub? [Re: monacoman] #1225951
05/02/12 11:46 AM
05/02/12 11:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
used I think is your only source .
Re: 1968 Charger Front Hub? [Re: JohnRR] #1225952
05/02/12 11:50 AM
05/02/12 11:50 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Are all the b-body hubs the same?
I have a set from a 66 Coronete, I am not using.
I have mechanical Aptitude.
I can screw up anything.
Re: 1968 Charger Front Hub? [Re: bboogieart] #1225953
05/02/12 12:09 PM
05/02/12 12:09 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Also you can use C-Body hubs and drums
Re: 1968 Charger Front Hub? [Re: MO_PA] #1225954
05/02/12 11:10 PM
05/02/12 11:10 PM
Kansas
Kansas
Thanks for the ideas. I tried a hub and drum from a 68 c body with 11 inch drums, and also a 71 c body and they both go too far back on the spindle, making the drums rub on the edge of the brake shoes. Then when I go to tighten up the lug nuts the wheel locks up. I have tried to space the hub out with washers, but that makes the whole car shake when I apply the brakes. I do have one correct hub that will work good on either side, so if I had one just like it, it would work. I can't seem to find a part number on the good one to compare. A disk brake conversion is looking better all the time.
