A833 Tansmission - Bell Housing Bolts #1225369
05/01/12 10:17 AM
05/01/12 10:17 AM
Upstate NY
454Baja Offline OP
454Baja  Offline OP
Upstate NY
Does the transmission use four threaded holes on the bell housing to bolt up? The right hand bottom corner on my bell has a thru hole (no threads) and a bolts with nut was used. The problem is the cover hits this nut / bolt and will not bolt on. If threaded is needed I will need to heli coil, just need to know what is correct mounting.
thanks
Re: A833 Tansmission - Bell Housing Bolts [Re: 454Baja] #1225370
05/01/12 10:20 AM
05/01/12 10:20 AM
Wheatfield, NY
Cuda340 Online work
Cuda340  Online Work
Wheatfield, NY
Yes, four bolts. The hole must have been stripped out and drilled.
Re: A833 Tansmission - Bell Housing Bolts [Re: Cuda340] #1225371
05/01/12 10:36 AM
05/01/12 10:36 AM
Upstate NY
454Baja Offline OP
454Baja  Offline OP
Upstate NY
thanks thats what i tought
You are down the road, I live in Rochester with family in lockport and pendleton
Re: A833 Tansmission - Bell Housing Bolts [Re: 454Baja] #1225372
05/01/12 11:47 AM
05/01/12 11:47 AM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
I used 7/16-14 .870 long time sert when I did my bell housing.
Re: A833 Tansmission - Bell Housing Bolts [Re: 454Baja] #1225373
05/01/12 04:51 PM
05/01/12 04:51 PM
Wheatfield, NY
Cuda340 Online work
Cuda340  Online Work
Wheatfield, NY
Yeah, I am not too far away. There are a bunch of members from the Western NY area. I can hit a baseball to pendleton and about 8 minutes away from lockport...
Re: A833 Tansmission - Bell Housing Bolts [Re: bp27] #1225374
05/01/12 05:50 PM
05/01/12 05:50 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Make sure the bolts are grade 8. DAMHIK
