408 vs 426 small blocks #1224976
04/30/12 07:35 PM
04/30/12 07:35 PM
right here
1BADDUSTER Offline OP
right here
Hey, thinking about a new stroked 360 build. I know a lot of times guys like to stick with the 4 inch stroke. Looking to build something with 500 and up horsepower. Would like to have 10.5:1 or 11:1 compression and use a 150-200 shot of n20. I also understand that the pistons hughes uses in the 426 kit are not recommended for n20. Is there another option here? What are some of your thoughts on the pros and cons. Here is an article with a 426 build in a valiant that got me thinking.
http://www.moparmusclemagazine.com/techa...ap/viewall.html
Re: 408 vs 426 small blocks [Re: 1BADDUSTER] #1224977
04/30/12 07:42 PM
04/30/12 07:42 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Just me, but, I would not buy a stroker in kit form if I were going to spray. For one you are wanting to make 700HP total. It can be done but, you can't make any boo boos or your block will go crunch clunk.
Leon
Re: 408 vs 426 small blocks [Re: Leon441] #1224978
04/30/12 09:28 PM
04/30/12 09:28 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
For that kind of hp why not build an N/A engine? That many cubes on a W8/9 head? You want compression so use it.
Re: 408 vs 426 small blocks [Re: Belvedere2] #1224979
04/30/12 10:40 PM
04/30/12 10:40 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I would agree with Leon, get a Nitrous specific piston, especially if you are a nitrous novice.
Alan Jones
Re: 408 vs 426 small blocks [Re: 1BADDUSTER] #1224980
04/30/12 10:43 PM
04/30/12 10:43 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
call ryan j.
Re: 408 vs 426 small blocks [Re: rickraw] #1224981
05/01/12 07:01 PM
05/01/12 07:01 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
DONT THINK ABOUT IT or talk about it just spray it. dont use good part in a stock block. that way when it breaks you are not MAY THE SPRAY BE WITH YOU MY FRIEND
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 408 vs 426 small blocks [Re: rickraw] #1224982
05/01/12 08:18 PM
05/01/12 08:18 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
call ryan j.
Just call anyone else, Or just ask the homo phobic
Leon. Maybe he can deal on some parts.
Re: 408 vs 426 small blocks [Re: mokid] #1224983
05/01/12 09:40 PM
05/01/12 09:40 PM
Ambridge, Pa.
Ambridge, Pa.
why is that?????
Re: 408 vs 426 small blocks [Re: rickraw] #1224984
05/01/12 11:40 PM
05/01/12 11:40 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mokid does not like Ryan or Leon for some reason.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 408 vs 426 small blocks [Re: 1BADDUSTER] #1224985
05/02/12 12:35 AM
05/02/12 12:35 AM
Az
Crizila Offline
Crizila  Offline
Az
One good option you might want to look at is dealing with your machinist on the parts. Often he can get a better deal than kit suppliers and you have more options when he is putting it together ( the parts that is ) for you. I am putting together 700 HP 408 blower motor using a stock 360 block. The block sonic tested good. half filled, Milodon steele 4 blt caps, Scatt forged crank, Eagle forged H beams, Icon blower pistons. I got a better $ deal from my machinist, than a kit supplier using basically the same parts. Another plus is that your machinist has more of an investment in making sure the parts are matched correctly so it will live.
Fastest 300
Re: 408 vs 426 small blocks [Re: 1967dartgt] #1224986
05/02/12 09:03 PM
05/02/12 09:03 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
Bingo
Re: 408 vs 426 small blocks [Re: mokid] #1224987
05/02/12 09:24 PM
05/02/12 09:24 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Bingo
Whats the reason/reasons??
Re: 408 vs 426 small blocks [Re: MIKES_DUSTER] #1224988
05/02/12 09:33 PM
05/02/12 09:33 PM
right here
right here
i appreciate any of the good feedback guys. I was looking more for a discussion on the benefits of extra stroke and if it was worth it etc. hp and tq differences between the 2.
Re: 408 vs 426 small blocks [Re: 1BADDUSTER] #1224989
05/02/12 09:40 PM
05/02/12 09:40 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
You usually get the same HP with either stroke and the bigger the stroke the lower the rpm it will happen.
I like that you can make the same power at more reasonable rpm levels. Just my
Keith
Re: 408 vs 426 small blocks [Re: Dunnuck Racing] #1224990
05/02/12 09:58 PM
05/02/12 09:58 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Keith
but also higher piston speed.
Re: 408 vs 426 small blocks [Re: domingo] #1224991
05/02/12 10:02 PM
05/02/12 10:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Keith
Piston speed stays about the same because you are now gonna turn less RPM. It is pretty much a wash in near sqaure engines.
Re: 408 vs 426 small blocks [Re: domingo] #1224992
05/02/12 10:03 PM
05/02/12 10:03 PM
Northern Indiana
Northern Indiana
Keith
Still not as hard on parts as a real high rpm stock stroke engine would be,the valvetrain is more stable due to less rpm. Biggest killer of engine in my opinion.
Re: 408 vs 426 small blocks [Re: domingo] #1224993
05/02/12 10:17 PM
05/02/12 10:17 PM
BPE Offline
BPE  Offline
Keith
You're right but think about it like this.. Let's say a 4" stroke makes peak power at 6500 rpm that's 72.2 ft. per sec. Now put a 4.250" stroke in it ans say it makes peak power at 6200 rpm, that's 73.2 ft. per sec. Not much difference huh. Will also have more torque to get the car moving. Less convertor and gear needed.
Rod
Re: 408 vs 426 small blocks [Re: BPE] #1224994
05/03/12 12:09 AM
05/03/12 12:09 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Keith
You're right but think about it like this.. Let's say a 4" stroke makes peak power at 6500 rpm that's 72.2 ft. per min. Now put a 4.250" stroke in it ans say it makes peak power at 6200 rpm, that's 73.2 ft. per min. Not much difference huh. Will also have more torque to get the car moving. Less convertor and gear needed.
Rod
Whatever a 4 inch stroke 4.06 bore motor will make at 6500 a 4.25 stroke 4.06 bore motor will make at 6112 or so and piston speed is even closer. You also get a lighter reciprocateing mass that translates in to faster ET
Re: 408 vs 426 small blocks [Re: HotRodDave] #1224995
05/03/12 12:17 AM
05/03/12 12:17 AM
gregsdart Offline
gregsdart  Offline
Putting money into a stock block and then wanting to spray it makes me nervous. What is the life span of a stock block with your goals in mind?
