Re: 408 vs 426 small blocks
[Re: 1BADDUSTER]
#1224977
04/30/12 07:42 PM
04/30/12 07:42 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Just me, but, I would not buy a stroker in kit form if I were going to spray. For one you are wanting to make 700HP total. It can be done but, you can't make any boo boos or your block will go crunch clunk.
Leon
[Re: rickraw]
#1224981
05/01/12 07:01 PM
05/01/12 07:01 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
DONT THINK ABOUT IT or talk about it just spray it. dont use good part in a stock block. that way when it breaks you are not MAY THE SPRAY BE WITH YOU MY FRIEND
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: rickraw]
#1224982
05/01/12 08:18 PM
05/01/12 08:18 PM
Posts: 252 St.Louis, Mo.
mokid
St.Louis, Mo.
call ryan j.
Just call anyone else, Or just ask the homo phobic Leon. Maybe he can deal on some parts.
[Re: rickraw]
#1224984
05/01/12 11:40 PM
05/01/12 11:40 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Mokid does not like Ryan or Leon for some reason.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1BADDUSTER]
#1224985
05/02/12 12:35 AM
05/02/12 12:35 AM
Posts: 7,506 Az
Crizila
Az
One good option you might want to look at is dealing with your machinist on the parts. Often he can get a better deal than kit suppliers and you have more options when he is putting it together ( the parts that is ) for you. I am putting together 700 HP 408 blower motor using a stock 360 block. The block sonic tested good. half filled, Milodon steele 4 blt caps, Scatt forged crank, Eagle forged H beams, Icon blower pistons. I got a better $ deal from my machinist, than a kit supplier using basically the same parts. Another plus is that your machinist has more of an investment in making sure the parts are matched correctly so it will live.
Fastest 300
[Re: 1BADDUSTER]
#1224989
05/02/12 09:40 PM
05/02/12 09:40 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
You usually get the same HP with either stroke and the bigger the stroke the lower the rpm it will happen. I like that you can make the same power at more reasonable rpm levels. Just my Keith
[Re: Dunnuck Racing]
#1224990
05/02/12 09:58 PM
05/02/12 09:58 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Keith
but also higher piston speed.
[Re: domingo]
#1224992
05/02/12 10:03 PM
05/02/12 10:03 PM
Dunnuck Racing
Northern Indiana
Keith
Still not as hard on parts as a real high rpm stock stroke engine would be,the valvetrain is more stable due to less rpm. Biggest killer of engine in my opinion.
[Re: domingo]
#1224993
05/02/12 10:17 PM
05/02/12 10:17 PM
Posts: 458 Michigan
BPE
Keith
You're right but think about it like this.. Let's say a 4" stroke makes peak power at 6500 rpm that's 72.2 ft. per sec. Now put a 4.250" stroke in it ans say it makes peak power at 6200 rpm, that's 73.2 ft. per sec. Not much difference huh. Will also have more torque to get the car moving. Less convertor and gear needed.
Rod
