E body pistal grip handle in a A body 4 speed Shifter #1224951
04/30/12 06:45 PM
04/30/12 06:45 PM
MICHIGAN
BB65Barracuda Offline OP
MICHIGAN
I was able to remove the stock A body shift handle with a couple feeler gauges, not a problem.
But after comparing the E body to it, looks a though I need to modifie the E body handle.
From the posts Ive seen I thought it would just pop in and I was on my way.
I hate to grind on such a nice piece.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: E body pistal grip handle in a A body 4 speed Shifter [Re: BB65Barracuda] #1224952
04/30/12 07:13 PM
04/30/12 07:13 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
I would change the tower in the shifter to the bolt-on style.
http://brewersperformance.com/proddetail.asp?prod=H0008
Dan
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: E body pistal grip handle in a A body 4 speed Shifter [Re: Dan Brewer] #1224953
04/30/12 07:19 PM
04/30/12 07:19 PM
MICHIGAN
MICHIGAN
How difficult is that to install?
Re: E body pistal grip handle in a A body 4 speed Shifter [Re: BB65Barracuda] #1224954
04/30/12 07:37 PM
04/30/12 07:37 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
complete teardown of the shifter. In The easy fix is to cut the pop in part off. Weld it to a short piece of flat stock. Drill the 2 holes and bolt the other shifter to it..
I am truckless..
Re: E body pistal grip handle in a A body 4 speed Shifter [Re: 340SHORTY] #1224955
04/30/12 07:43 PM
04/30/12 07:43 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
I used a bbody non console handle and a hurst comp plus on my 67 bcuda. worked great.
=daty
Re: E body pistal grip handle in a A body 4 speed Shifter [Re: Daty Rogers] #1224956
05/04/12 01:07 PM
05/04/12 01:07 PM
MICHIGAN
MICHIGAN
I got a e body bolt in shifter mech..
