STARTER - VOLTAGE - CLICK CLICK
#1224787
04/30/12 01:44 PM
04/30/12 01:44 PM
Posts: 14 Texas
Cajun
Texas
I have a 1971 Challenger with a 440 engine.
No problems with the car before having this one. ANY HELP would be appreciated.
I start the car and take it out for a spin , drive 10 miles and stop. The car sits for about two hours, go to start it --- click click. Now it is turning dark outside and my very first thought was the battery. The battery I have in the car is a Optima and about two years old. Never had to jump it , until now “so I thought”.
Get a second car and cables and try to jumb , click. I scratch my head , put in a new battery – click. So I push the car to start it and head home , put car in garage .
Next day: Check the grounds “and clean”. – click. Check all wiring terminals and clean – click.
The starter I had on there is a MSD Mini Starter about two years old. Take the starter off and bench test it , tested fine. Put starter back on – click , ran ground to the starter tried to start – click.
Replace the relay – clean all connections – click
Buy new starter “Summit mini” install new starter – click
When I turn the ignition switch the starter pinion gears do engage but it will not spin. It acts like it is not getting enough voltage. Jump the relay – click
When I turn the key my volt meter “in the car” reads 8-9 volts.
New: battery , starter , relay Checked and cleaned: all ground cables , fittings and wiring,.
I am lost.
Re: STARTER - VOLTAGE - CLICK CLICK
[Re: Cajun]
#1224789
04/30/12 03:49 PM
04/30/12 03:49 PM
RapidRobert
I'd put another known good battery in. If good there, one of the large cable/connections is poor
[Re: Cajun]
#1224796
05/01/12 05:18 PM
05/01/12 05:18 PM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
what happens if you turn the key on, and cross the terminals at the relay?? The 72 used to NEED a started button in addition to the ignition switch. I replaced the ignition switch, and it starts with the key. When the ignition switch was bad, it would either: 1) Act like a dead battery...no juice any where 2) Click like a drained battery, even with a known good battery 3) starter would rotate slightly and VERY noisely, then quit altogether My money is on a bad ignition switch
