Modernizing the fuel sending units
#1224735
04/30/12 11:15 AM
04/30/12 11:15 AM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
If I took my 3/8" aftermarket fuel sending unit and cut off the float level, replaced it with an aftermarket unit that had a different Ohm reading, and put in an Autometer gauge on my dash, in theory, it should read correctly....right?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Modernizing the fuel sending units
[Re: Pyper70]
#1224737
04/30/12 11:37 AM
04/30/12 11:37 AM
Andrewh
it should. I have thought about that, and this https://www.pegasusautoracing.com/productselection.asp?Product=2524 no moving parts. but I would see if a modern equivelent worked so I didn't have to change the gauge. 0-90 Ohms most GM cars, 1965-up 73-10 Ohms pre-1989 Fords & most Chryslers 240-33.5 Ohms Industry standard, works on many popular cars 0-30 Ohms most pre-1965 GM cars 16-158 Ohms most '89-up Fords
[Re: Andrewh]
#1224738
04/30/12 11:44 AM
04/30/12 11:44 AM
Pyper70
Athens, Greece
thats for a fuel cell though....I am wanting to keep the factory fuel tank and use the factory sending unit just altering the level sensor to the updated one
[Re: dusterbd13]
#1224741
05/01/12 11:51 AM
05/01/12 11:51 AM
Pyper70
Athens, Greece
Looks I will be purchasing and seeing what I can do to make it work properly then.
