Modernizing the fuel sending units #1224735
04/30/12 11:15 AM
04/30/12 11:15 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
If I took my 3/8" aftermarket fuel sending unit and cut off the float level, replaced it with an aftermarket unit that had a different Ohm reading, and put in an Autometer gauge on my dash, in theory, it should read correctly....right?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Modernizing the fuel sending units [Re: Pyper70] #1224736
04/30/12 11:16 AM
04/30/12 11:16 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Re: Modernizing the fuel sending units [Re: Pyper70] #1224737
04/30/12 11:37 AM
04/30/12 11:37 AM
Andrewh Offline
Andrewh  Offline
it should.
I have thought about that, and this
https://www.pegasusautoracing.com/productselection.asp?Product=2524
no moving parts.
but I would see if a modern equivelent worked so I didn't have to change the gauge.
0-90 Ohms most GM cars, 1965-up
73-10 Ohms pre-1989 Fords & most Chryslers
240-33.5 Ohms Industry standard, works on many popular cars
0-30 Ohms most pre-1965 GM cars
16-158 Ohms most '89-up Fords
Re: Modernizing the fuel sending units [Re: Andrewh] #1224738
04/30/12 11:44 AM
04/30/12 11:44 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
thats for a fuel cell though....I am wanting to keep the factory fuel tank and use the factory sending unit just altering the level sensor to the updated one
Re: Modernizing the fuel sending units [Re: Pyper70] #1224739
04/30/12 11:50 AM
04/30/12 11:50 AM
Andrewh Offline
Andrewh  Offline
I understand the whole unit is for a fuel cell, but the same concept applies. if it can be disassembled. and placed in a regular fuel tank bolted to the old sending unit, it would do the same job.
it can be ordered in any length and any ohm range.
so you can keep your old dash stock if you want.
otherwise your idea works fine, replacing the gauge and sending unit at the same time.
Re: Modernizing the fuel sending units [Re: Andrewh] #1224740
04/30/12 09:06 PM
04/30/12 09:06 PM
albemarle, NC
dusterbd13 Offline
dusterbd13  Offline
albemarle, NC
i did exactly this a few years ago. i will say that i didnt spend enpugh time working on my float, as my gauge isnt exactly right. in my a body, i have a 16 gallon tank. at empty, i only put in 12 gallons.
so yes, it can be done. mine was done with a pair of bolts, as that is what the sender was assembled with from autometer.
michael
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: Modernizing the fuel sending units [Re: dusterbd13] #1224741
05/01/12 11:51 AM
05/01/12 11:51 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Looks I will be purchasing and seeing what I can do to make it work properly then.
