Re: HELP - 4.7L coil pack bolt snapped off
[Re: Valiant_Showoff]
#1224723
05/03/12 04:14 PM
05/03/12 04:14 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
I've never even checked the oil on a 4.7L.
However a buddy of mine has done quite a bit of work with them, and if his memory is correct the intake bolts are the captive type. So are the valve covers.
With that style of bolt, the whole intake manifold can be removed and the bolts come off with it. Then, the bolts usually can't be removed from the part without taking the part completely off and then grinding the retainer part of the bolt off on the bottom.
As you stated, don't put much stress on it...the intake can be broken and ususally is not serviced, so if you break it then you will have to scare up a used one.
My buddy also recently aquired a used 4.7 ram and did quite a bit of work to it, and he states maybe one of the coil mounts survived...all the rest snapped right off. So I guess it is a pretty common issue.
Rich H.
Esse Quam Videri
