Re: knocking 383
[Re: lake71383]
#1224598
04/30/12 05:29 AM
04/30/12 05:29 AM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Pull the valvecover and check for a broken rocker arm. The pushrod tends to get pushed through the rocker tip and then it will make just such a noise as you mentioned. Most wrist-pin or piston slap noises lessen when you pull the plugwire away. The factory Mopar rockers are notorious for breaking. Good luck.
Re: knocking 383
[Re: lake71383]
#1224600
04/30/12 06:05 PM
04/30/12 06:05 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
start it up again, pull 1 wire at a time till you find the 1 that is knocking. Valve train is usually a clattering sign. Rod and wrist pin problems are a knocking sound. Either way you have a problem that most likely indicates a teardown is in your future.
I am truckless..
Re: knocking 383
[Re: jeebis44]
#1224603
05/01/12 02:45 AM
05/01/12 02:45 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
check your fuel pump push rod.
I am truckless..
Re: knocking 383
[Re: 340SHORTY]
#1224606
05/01/12 02:34 PM
05/01/12 02:34 PM
Posts: 4,848 Memphis
HemiRick
Memphis
No reason to check fuel pump push rod if it were worn enough to make a noise you wouldn't have any fuel pressure either....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: knocking 383
[Re: HemiRick]
#1224608
05/01/12 03:05 PM
05/01/12 03:05 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Pulling one plug at a time didn't isolate it.
so next, remove the intake and exhaust pushrods for one cylinder at a time. see if you can narrow it down to valvetrain somewhere.
if you still can't find it, then it really doesn't mater what the noise is, because you need to pull the motor out and rebuild it.
**Photobucket sucks**
Re: knocking 383
[Re: 70Cuda383]
#1224609
05/01/12 03:38 PM
05/01/12 03:38 PM
Posts: 5,161 CT
GTX MATT
CT
I'm just going to mention this because I know two people who have done this, not really sure its your problem, but I know two people who both blew the ring lands out of #1 on a 383. Both left the bores undamaged, but they had be replace a piston.
