Hey guys!
Well I just got my Coronet out to the track for the first time after repainting it and rebuilding the engine, plus all the issues I've had to put up with and it just continues!
Started the car up, warmed it up to 180... When I'm in Park or Neutral, I can hit the throttle and I have perfect response, engine doesn't backfire, or stumble or anything...
Now when I have it in gear and I slam on it, it'll stumble real bad and then die out. If I'm easy on the throttle it'll go, but I just can't hammer it...
Carburetor has been rebuilt and I am at 12 degrees before TDC on initial timing. I got the 6T MSD Box w/ Master Blaster Coil. Its a 440, got a 700cfm Holley Double Pumper on there, Hughes "Whiplash" Cam [.518 Lift], 2500 Stall Converter, and a Cheetah Manual Valve Body installed. I was thinking maybe it was low on trans fluid, because I know that engines do strange things when it's low... But it was right where it needed to be...
All advice is welcome!
Thanks, Craig
