Only does this when it's cold #1224514
04/29/12 09:59 PM
04/29/12 09:59 PM
Mid Michigan
Coronet-R/T-Rag Offline OP
Mid Michigan
After I fire up my 67 Coronet it only runs on 7. As it warms up it picks up the other cylinder and runs great after that. I've put in a new set of plugs and it still does it. What could it be? Plug wire?
Re: Only does this when it's cold [Re: Coronet-R/T-Rag] #1224515
04/29/12 10:06 PM
04/29/12 10:06 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Sounds like it could be the start of a head gasket. After it warms up it burns the coolant out and runs okay. When it is cold you might pull the plug and see if there is any traces of coolant in the cylinder. Hopefully I am wrong.
Re: Only does this when it's cold [Re: ralphie361] #1224516
04/29/12 10:09 PM
04/29/12 10:09 PM
Mid Michigan
Mid Michigan
I've also been worried about this. I put a set of CnC'd Stealth heads on it last year and now I'm wondering if I've got a gasket going or a CRACK?
Re: Only does this when it's cold [Re: Coronet-R/T-Rag] #1224517
04/29/12 10:12 PM
04/29/12 10:12 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Any valvetrain noise? I've seen older engines have lifters bleed down and take a while to fully pump up.
Also, a vacuum leak on one cylinder could be the cause.
Re: Only does this when it's cold [Re: RodStRace] #1224518
04/29/12 10:16 PM
04/29/12 10:16 PM
Mid Michigan
Mid Michigan
It's got a solid lifter cam. Maybe a intake gasket leak on one cylinder that seals as the engine warms? It seems to start harder when It's cold than it used to....Hmmmm.
Re: Only does this when it's cold [Re: RodStRace] #1224519
04/29/12 10:19 PM
04/29/12 10:19 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Youre right, maybe a small intake manifold gasket leak, when it warms it swells. When its cold try and spray some carb cleaner around the gaskets and see if it smooths out.
Re: Only does this when it's cold [Re: ralphie361] #1224520
04/29/12 10:22 PM
04/29/12 10:22 PM
Mid Michigan
Mid Michigan
A couple of times it's really ran crappy and I get a "popping" in the mufflers. That sounds like unburnt fuel? That's why I thought ignition.
Re: Only does this when it's cold [Re: Coronet-R/T-Rag] #1224521
04/29/12 10:50 PM
04/29/12 10:50 PM
Mid Michigan
Mid Michigan
Buuut it could be coolant not letting the plug fire and loading the mufflers with fuel. Hey, this is just like therapy. I'm answering my own questions.
Re: Only does this when it's cold [Re: Coronet-R/T-Rag] #1224522
04/29/12 10:53 PM
04/29/12 10:53 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
We'll save you therapy money so you can fix your car
Re: Only does this when it's cold [Re: ralphie361] #1224523
04/29/12 11:00 PM
04/29/12 11:00 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
"anything' that causes a misfire is going to as an after-effect also cause popping in the exhaust.
You can swap in new plugs and wires if you are about due. If you have the opportunity, you can also start it and allow it to run for a bit while it's rough, then shut it off and compare plugs to determine which cylinder(s) are missing.
If it's a coolant leak, the exhaust will have a sweet smell.
Re: Only does this when it's cold [Re: RodStRace] #1224524
04/30/12 07:45 PM
04/30/12 07:45 PM
Mid Michigan
Mid Michigan
That's the thing, no sweet smell or white smoke. Last time I adjusted the valves I tightened the lash a little more than I have in the past but that was last fall and it ran good after that. I'm thinking I've got a valve that's too tight and not sealing until it warms up but lash loosen over time not tightens?
