Question about my slicks
#122414
09/18/08 07:43 AM
09/18/08 07:43 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
76 Volare ladder bars, Alden coilover rear. The car has always hooked well, even with the M/T street radial. Now it has M/T 29.5 x 9 slicks. Have had no problem from them at all. I have prob 40 passes on them so far. All of a sudden they will not hook. I have plenty wear holes left. I have aired them up and down and keep spinning. When comming out of the water, they hook real hard, pull up, and spin out of the hole. I hate to buy more tires if there is something else wrong. Anybody??
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Question about my slicks
[Re: StandOnIt]
#122415
09/18/08 09:35 AM
09/18/08 09:35 AM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Have you tried rotating them/swap one side for the other side yet? Sometimes that will bring them back
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#122416
09/18/08 11:32 AM
09/18/08 11:32 AM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
I ran Mickey Thompson for years. That is the reason I switched. Tires went away on some sets. For every one or two good sets I had I had a set that I was unhappy with. Buy a Phoenix tire and you will never go back. I run them on three different cars for the last 6 years. My 2
Why does divorce cost so much?
Because it is worth it!!!!!
[Re: Aspen7695]
#122418
09/19/08 07:53 AM
09/19/08 07:53 AM
StandOnIt
Baton Rouge, La.
I have rotated them once. I didnt start messing with anything before it started spinning, started adjusting coilovers after it started. I roll through the water, clean them off and pull to dry ground to heat. I had better luck with the radial for sure.
