Reverse Rod Setup on Hurst Shifter - 70RR #1224086
04/29/12 10:30 AM
04/29/12 10:30 AM
Upstate NY
454Baja Offline OP
454Baja  Offline OP
Upstate NY
I posted last week and discovered I did not have the right reverse link for my 70 roadrunner. I now have a new one but need to setup the reverse link. The 7174 lever arm does not have a pin hole to align and I have the threaded link adjusted all the way back for on reverse, my prblem is the 7174 lever is not centered and I seem to running out of travel for shifting.
What i need is a photo or any setup information relative to the hurst shifter on a A833 4 speed for positioning.
Re: Reverse Rod Setup on Hurst Shifter - 70RR [Re: 454Baja] #1224087
04/29/12 08:39 PM
04/29/12 08:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the shifter has to be in neutral and all the levers are in line with each other , this has the trans in neutral .
Re: Reverse Rod Setup on Hurst Shifter - 70RR [Re: JohnRR] #1224088
04/29/12 08:54 PM
04/29/12 08:54 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
the shifter has to be in neutral and all the levers are in line wite ach other , this has the trans in neutral .
This is from the FSM for a 70 Charger
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Reverse Rod Setup on Hurst Shifter - 70RR [Re: 70sixpkrt] #1224089
04/29/12 09:26 PM
04/29/12 09:26 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Nice pic That tool looks easy enough to make and use.
Gus
64 Plymouth Savoy
Dana 60
Re: Reverse Rod Setup on Hurst Shifter - 70RR [Re: fourgearsavoy] #1224090
04/30/12 12:11 AM
04/30/12 12:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gus
It is , I made one a number of years back
