Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? #1224055
04/29/12 10:16 AM
04/29/12 10:16 AM
USA
69Charger500 Offline OP
USA
I'm fixing up my mother's 2004 PT Cruiser to make it road worthy, it sat for many years...
It has 29,000 miles, and the OEM tires and chrome wheels.
All four of the tires' treads still look new (some sidewall checking), but lose air after about 1 week, they go completely flat; the car is just sitting in my garage for now.
Is this an issue with the wheels or the tires? I'm concerned if I put new tires on it, it will have the same problem; maybe the chrome wheels are pitted or something and causing the tires to leak?
Anyone have any experience with this issue or any thoughts?
Thanks,
Mike
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: 69Charger500] #1224056
04/29/12 10:22 AM
04/29/12 10:22 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Did you use soap water to see where there leaking yet?
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: Challenger 1] #1224057
04/29/12 10:28 AM
04/29/12 10:28 AM
USA
USA
Not yet, will do that this morning if it gets out of the 30s here!
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: 69Charger500] #1224058
04/29/12 10:32 AM
04/29/12 10:32 AM
Cincinnati, Ohio
Cincinnati, Ohio
Check the valve stems real close if there rubber.
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: 69Charger500] #1224059
04/29/12 10:32 AM
04/29/12 10:32 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Some chrome wheels tend to peel inside the wheel. If that happens around the bead the tires can't seal to the wheel and you lose pressure.
- Stu Harmon
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: 69Charger500] #1224060
04/29/12 10:39 AM
04/29/12 10:39 AM
USA
USA
Just tried the soapy water, not seeing anything obvious yet, maybe it's leaking on the inboard side of the wheel? Valve stem seems okay.
Guess I'll pull them and look closer...
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: 69Charger500] #1224061
04/29/12 10:43 AM
04/29/12 10:43 AM
USA
USA
Thanks for the tips!
Not sure if I should try to fix this, or just go for new wheels and tires...
Sounds like one of those problems that might not go away too easily.
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: 69Charger500] #1224062
04/29/12 10:51 AM
04/29/12 10:51 AM
places
79powerwagon Offline
places
Seriously???? Get new tires! Those are at least 8 years old already!
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: 79powerwagon] #1224063
04/29/12 11:13 AM
04/29/12 11:13 AM
middle Tennessee
mopower440 Offline
mopower440  Offline
middle Tennessee
guaranteed they are leaking around the bead and/or the valvestems are indeed dryrotted, see this everyday..
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: mopower440] #1224064
04/29/12 11:17 AM
04/29/12 11:17 AM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
Yup. Our Sebring drop top has/has the very same issue with the aluminum wheels. Pull the tires off, sand the rim/bead area and reseal them using the black rubbery tire sealer stuff.
Karma has no menu. You get served what you deserve.
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: SKR8PN] #1224065
04/29/12 11:30 AM
04/29/12 11:30 AM
Cincinnati, Ohio
Cincinnati, Ohio
OT a little.
My 99 pickup truck recently had the front left tire blow out sitting in the driveway. It leaked out of the valve stem, just sitting there. We heard it and walked out while it was hissing air.
It has 87K miles on it and I remember changing the front tires at around 65K miles but didn't replace the rubber stems that day because I didn't have the right size on hand.
I put the 12 year old spare on it and the valve stem on it was crusty. lol It'll get me to work so I can fix my front tire. Never had the spare out until recently.
So exactly 2 days later sitting in my driveway again the right front tire goes flat, I take my air hose and air it up and sure enough that valve stem on that side was leaking too, damn only 12 years out my valve stems! They sure don't make em like they used too!!
Well when the second front tire blew I still had the spare mounted and I hadn't repaird the first one yet. So I aired it up and if I bent the stem over some it would almost stop leaking. So I took a peice of budweiser 12 pack and folded it up and wedged it against my valve to make it stop leaking. Drove it 2 miles to work and replaced all 3 valves stems. lol
The rear dually wheels need them next, but they were replaced when I got new tires. So I'm putting them off until either I need new tires or one goes flat.
Funny how both front valves stems had the almost exact same life span.
Actually I replaced the rubber stems with brass ones that I had the other day. so no more rubber replacements needed now.
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: Challenger 1] #1224066
04/29/12 07:43 PM
04/29/12 07:43 PM
Probably not related but I have had this issue a couple of times over the years with tires. The manufacturer places a fairly thick small decal near the tire bead. The tires are mounted and you lose air sloooowly. Like it takes a month to lose 10psi. This decal causes a small leak around itself and the rim necessitating letting the air completely out of the tire and prying the bead back in the spot of the decal and peeling it off with a razor.
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: SKR8PN] #1224067
04/29/12 07:45 PM
04/29/12 07:45 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Yep - I had to do this with all 3 of my chromed aluminum rim cars - find a place that uses a good bead sealer - many tire shops don't have it or use the watery stuff because it's cheaper - grind the beads down and apply - I've had the best luck at tire shops that service 4WD and Commercial tires - last a few years and you have to do it again.
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: SSAAHemiFan] #1224068
04/29/12 07:47 PM
04/29/12 07:47 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
ALso - Check the rims closely when the tires are off - I've seen some with holes in them or cracked from corrosion.
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: SSAAHemiFan] #1224069
04/30/12 06:57 PM
04/30/12 06:57 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
My PT Cruiser used to have problem with the tires loosing air. I had a second set of takeoff wheels and tires from another one that only had 40 miles on them. I used those as my first replacement set. Same problem, would lose air. I changed from the OE Goodyear tires to BF Goodrich Traction T/A and never had a leaking problem again. Same factory chrome aluminum wheels. Maybe costco peeled off the sticker? I never looked. I've had two sets of the BFGs.
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? #1224070
04/30/12 08:59 PM
04/30/12 08:59 PM
Cincinnati, Ohio
Cincinnati, Ohio
Probably not related but I have had this issue a couple of times over the years with tires. The manufacturer places a fairly thick small decal near the tire bead . The tires are mounted and you lose air sloooowly. Like it takes a month to lose 10psi. This decal causes a small leak around itself and the rim necessitating letting the air completely out of the tire and prying the bead back in the spot of the decal and peeling it off with a razor.
This bar code on the tire get's mounted by the valve stem, that's what I was taught. Helps with balance?
That is if the tire is is not marked on the sidewall with yellow or red dots.(big truck tires)
I have mounted scores of tires without messing with that bar code decal alinging it with the valve stem. Never a problem with it sealing.
Generally speaking alloy rims need air more often than steel wheels, been a fact forever.
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: Challenger 1] #1224071
04/30/12 10:52 PM
04/30/12 10:52 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
8 years with chrome wheels and a lot of sitting.
Add how many times the temperature has changed and the heating/cooling cylces caused moisture to build up inside the tire.
Result? Calcium buildup between the alloy wheel and tire bead.
A natural chemical reaction that cannot be avoided.
Break them down,clean and reseal make sure bead sealer is applied.
If you are running the original equipment tires (Eagle LS or Eagle RS-A's),replace them.Sure they may have lots of tread,but I guarantee if you drive the car everyday,the belts in the tires will separate within the next 10K miles.All the moisture inside the tire can rust the steel belts
The rubber is no longer soft and pliable,traction will be a big concern in wet conditions and may squeal under braking and/or cornering.
GM and Chrysler chromed alloy wheels of that era were notorious for the chrome plating corroding and even delaminating from the bead.
I had seen many of these wheels cause many a flat tire.In extreme cases especially in the northern climates where road salt is used,the rims are deemed junk after a few years of winter driving.
This may not be your case,however,but for a piece of mind get them broken down and inspected,clean the rims,replace the tires,and fill them with nitrogen.
Hope this helps.
BTW,I work at a Goodyear Tire shop..
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: 68Cbarge] #1224072
04/30/12 11:14 PM
04/30/12 11:14 PM
IN
ahy Offline
ahy  Offline
IN
All good advice... another option. Call the Tire Rack and see what a new set of wheels with mounted tires would cost. If you aren't too picky about wheel type, it could be the lowest cost and most reliable option. Consider breaking down and cleaning up your current wheels (if possible) for a set of snows.
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: SKR8PN] #1224073
05/01/12 12:26 AM
05/01/12 12:26 AM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
I just went thru this a few weeks ago with my 2004 VW GTI. The tire keep going flat every 2 weeks. The tires are only 1 year old. The tire shop could not find the leak so they sanded the rim/bead area (aluminium wheel) and resealed with the black stuff. It has been a few weeks and no problems.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: Tire Experts: 2004 PT Cruiser Tires Won't Hold Air?? [Re: loco340cuda] #1224074
05/01/12 07:13 AM
05/01/12 07:13 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive done tires since the 60s.I always use bead sealer and new stems when we mount tires.Mopar really didnt have corossion problems on the beads.Now GMs thats a different story.Usually you can find a leak if you put the tire in a water dip tank if the shop has one.I would also use soapy water around the beads with the tire laying flat.Look for tiny bubbles.Rocky
Chrysler Firepower
