Syncronizer questions? #1223874
04/28/12 10:44 PM
04/28/12 10:44 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, I was rebuilding my 833, I have 2 overdrive tranny's to rob the wider syncros from.
The gears in my tranny were great but I wanted to use the newer syncros but the overdrive 3-4 hub did not fit the shaft. Is there 2 differnet hubs? Are there OD/non OD hubs?
Are the sliders different between the newer and older syicros interchangeable?
Re: Syncronizer questions? [Re: astjp2] #1223875
04/28/12 10:55 PM
04/28/12 10:55 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The 3-4 hub is smaller in the OD unit but the slider is the same.I may have a wide key hub on the shelf if you need one.
I will look tomorrow if you need one.
Gus
64 Plymouth Savoy
Dana 60
Re: Syncronizer questions? [Re: fourgearsavoy] #1223876
04/28/12 11:46 PM
04/28/12 11:46 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Please!
