727 Valvebody install Q #1223801
04/28/12 08:35 PM
04/28/12 08:35 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
Anybody know the proper torque value for the valve body bolts (727).
My FSM says 100 inch lbs in the text but 35 inch lbs in the tightening reference section.
I also see the trans pan is torqued to 150 inch lbs, is that correct?
Thanks,
Jason
Re: 727 Valvebody install Q [Re: CUDAJAS] #1223802
04/28/12 10:58 PM
04/28/12 10:58 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
VB is 100 inch lbs.
