Both brackets are definitely slightly bent. No big deal to take them off, carefully straighten them and reassemble them, possibly with fresh rubber if you wish. This will pull the "washer" away from where it's rubbing on the lower control arm. If you are careful, you can do it without too much damage to the current appearance and patina of the parts. It looks like you have a nice rust free car there.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
