Stage VI max wedge rocker offset #1223575
04/28/12 03:40 PM
04/28/12 03:40 PM
Out of the State of Confusion
blue_stocker Offline OP
I have noticed MP rockers for stage VI heads have a .485" offset for the intakes, so now the BIG question is...does that .485" offset pertain to the standard (port window) stage VI or the max wedge window stage VI casting, or do they use a different offset rockerarm ?
Re: Stage VI max wedge rocker offset [Re: blue_stocker] #1223576
04/28/12 04:56 PM
04/28/12 04:56 PM
Idaho
LaRoy Engines Offline
Idaho
The Stage VI heads I have here with the standard port window, P4529335, use a factory offset. What is that .200-.250? Can't remember right now.
Re: Stage VI max wedge rocker offset [Re: LaRoy Engines] #1223577
04/28/12 05:56 PM
04/28/12 05:56 PM
Arizona
Chris'sBarracuda Offline
Arizona
Max Wedge Stage 6 uses .485 offset.
Chris..
Re: Stage VI max wedge rocker offset [Re: blue_stocker] #1223578
04/28/12 06:38 PM
04/28/12 06:38 PM
Thanks Jim and Chris for the info, much appreciate!
