Re: bracket race 360
[Re: mechanic190]
#1223448
04/28/12 09:56 AM
04/28/12 09:56 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
First, what family of 360? is it an LA or a magnum?
with a 3000 stall, I'd think a cam around 230 degrees of duration @ .050 lift would probably work alright, assuming stock stroke 360. what are your rear gears?
**Photobucket sucks**
[Re: mechanic190]
#1223457
04/29/12 01:12 AM
04/29/12 01:12 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Gonna need some compression, gonna have to switch pistons or mill/replace heads. No factory LA head/piston combo will get you much over 8 to 1 compression and any "summit" or "eddelbrock" (chevy) cam will not do much with that low compression, certainly not low 12s. If you are gonna stick with the factory low compression set up you need a quality custom cam with mopar specific lobes and a tight LSA to artificialy build compression with out loseing flow under the curve. Spend money on pistons, heads or cam, you can't skimp on EVERYTHING!
[Re: HotRodDave]
#1223458
04/29/12 01:21 AM
04/29/12 01:21 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
get a stock eliminator cam for it... i would throw some kb107s in it they are cheap. and go with what you got...ill say high 12's
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
