bracket race 360 #1223447
04/28/12 08:21 AM
04/28/12 08:21 AM
Wyoming
mechanic190 Offline OP
Wyoming
So here's the deal I have a 360 la and i'm wanting to run it in bracket races. I'm being pushed to slap it together and run her but that's not where I wanna start. So I need some help building it on a budget. I'm thinkin run the factory heads for now and possibly the factory flat top pistons. I have a 3000 stall converter so I wanna run a big cam. Have a edl340 intake and I believe 600 Holley. How big can I go and what's needed to run anything other than a hyd flat tappet cam? Any other cheap power adders would be help ful too. Take a guess what it'll run in a quarter installed in a 3600 pound d150 with 4.56
Re: bracket race 360 [Re: mechanic190] #1223448
04/28/12 09:56 AM
04/28/12 09:56 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
First, what family of 360? is it an LA or a magnum?
with a 3000 stall, I'd think a cam around 230 degrees of duration @ .050 lift would probably work alright, assuming stock stroke 360. what are your rear gears?
**Photobucket sucks**
Re: bracket race 360 [Re: mechanic190] #1223449
04/28/12 11:29 AM
04/28/12 11:29 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Try www.mopar1us/dyno.html. I have used many of these combos for good cheap results.
Re: bracket race 360 [Re: A/MP] #1223450
04/28/12 12:19 PM
04/28/12 12:19 PM
Wyoming
Wyoming
Like I said before its an la block and 4.56 gears. How talk of lift can I go with factory heads with no modifications
Re: bracket race 360 [Re: mechanic190] #1223451
04/28/12 01:37 PM
04/28/12 01:37 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
about .500 at the valve.
Tony
70 AARCuda Vitamin C
Re: bracket race 360 [Re: 70AARcuda] #1223452
04/28/12 03:51 PM
04/28/12 03:51 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Don't get too carried away with the big cam idea. If you have a big cam with that little intake and carb, low stall converter, will be a turd in that heavy truck. Match the parts you have to work with, it will be much quicker...
Re: bracket race 360 [Re: mechanic190] #1223453
04/28/12 05:20 PM
04/28/12 05:20 PM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
What compression are you planning?
Shoot for 10.5:1 or so, Edlebrock performer RPM cam, AirGap intake, well tuned 750 DP will get that truck into the very low 12's or even high 11 in good air. Stay away from power adders for bracket racing unless you really know what you're doing.
Re: bracket race 360 [Re: mechanic190] #1223454
04/28/12 05:59 PM
04/28/12 05:59 PM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
What year 360? Didn't realize there were some with flat tops stock.
Re: bracket race 360 [Re: POZEST] #1223455
04/28/12 06:28 PM
04/28/12 06:28 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Early 360s had flat top pistons. Ditch the 600 holley and get a 750. the LD 340 intake will work fine. Use steel shim headgaskets to keep the compression up. Spend some time doing some good bowl work and port matching on your stock heads. Its not that hard to do and if your on a budget it can yield some good results if you take your time and do it correctly. A cheap summit or purpleshaft cam will make decent power if you cant spend much money. Buy the best torque converter you can afford
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: bracket race 360 [Re: 71yelladustr] #1223456
04/28/12 08:07 PM
04/28/12 08:07 PM
Wyoming
Wyoming
Thanks for the input. The goal for the pickup is to run 12s with factory heads and pistons but it needs to run faster than 14s because that's what my brothers car ran last year with a 360 in a 74 scamp. I think he ran a 268 adv cam with factory heads and pistons with 3.91 gears and street bfgs
Re: bracket race 360 [Re: mechanic190] #1223457
04/29/12 01:12 AM
04/29/12 01:12 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Gonna need some compression, gonna have to switch pistons or mill/replace heads. No factory LA head/piston combo will get you much over 8 to 1 compression and any "summit" or "eddelbrock" (chevy) cam will not do much with that low compression, certainly not low 12s. If you are gonna stick with the factory low compression set up you need a quality custom cam with mopar specific lobes and a tight LSA to artificialy build compression with out loseing flow under the curve. Spend money on pistons, heads or cam, you can't skimp on EVERYTHING!
Re: bracket race 360 [Re: HotRodDave] #1223458
04/29/12 01:21 AM
04/29/12 01:21 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
get a stock eliminator cam for it...
i would throw some kb107s in it they are cheap.
and go with what you got...ill say high 12's
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
