no turn signal on 73 challenger #1223358
04/27/12 10:47 PM
04/27/12 10:47 PM
michigan,usa
W
woody02 Offline OP
woody02  Offline OP
W
michigan,usa
.i have no turn signal,front or rear.bulbs are good.hazzards and brake likes are good.running lights good.chasing this concern around,and i was hoping someone might point me in a direction.1st-my flasher is a 3 terminal.1 red,1 yellow,1 yellow/blk.the red wire to flasher shows power,at flasher connector.however the red wire at connector of turn signal has no power.i assume the other 2 flasher wires must go to bulbs?does power go from flasher to turn signal,or from turn signal to flasher?
Re: no turn signal on 73 challenger [Re: woody02] #1223359
04/28/12 12:10 AM
04/28/12 12:10 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There are rtwo flashers one for ts and the other for hazzards. The power goes through the flasher to the switch.
