Rallye gauge decal sets #1223263
04/27/12 09:14 PM
04/27/12 09:14 PM
dark side of the moon
Dougsmopars Offline OP
Any one used them? They any good? How hard to install them? Not a concourse car but would like the cluster to look good.
Re: Rallye gauge decal sets [Re: Dougsmopars] #1223264
04/27/12 11:49 PM
04/27/12 11:49 PM
Lakewood, Colorado
runnerrt Offline
runnerrt  Offline
Lakewood, Colorado
Did mine on my 69 Bee. Not to hard to do,Clean and paint the original face and install your decal. I can post some pictures tomorrow if you like.
1969 Super Bee High School car I got back 2004 Ram 2500
Re: Rallye gauge decal sets [Re: runnerrt] #1223265
04/27/12 11:57 PM
04/27/12 11:57 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
They are a much cheaper alternative than having your gauges redone. They work ok, have a tendency to lift over rivets and bumps. I had some on my 69 RR. If you need a Charger (B body) gauge set in white I'll send you an extra set I got for the cost of shipping.
Re: Rallye gauge decal sets [Re: runnerrt] #1223266
04/28/12 11:39 AM
04/28/12 11:39 AM
Thanks. That would be great. Do the pointers come off easy? I never tried to remove them.
Re: Rallye gauge decal sets [Re: Dougsmopars] #1223267
04/28/12 09:13 PM
04/28/12 09:13 PM
Lakewood, Colorado
runnerrt Offline
runnerrt  Offline
Lakewood, Colorado
Clock and speedo are the only one that come off. You need to be careful but they slide off
Re: Rallye gauge decal sets [Re: runnerrt] #1223268
04/28/12 09:29 PM
04/28/12 09:29 PM
Mine has the tach but no clock. It's not a tic toc. Does the tach pointer come off also?
Re: Rallye gauge decal sets [Re: Dougsmopars] #1223269
04/29/12 01:12 AM
04/29/12 01:12 AM
Lakewood, Colorado
runnerrt Offline
runnerrt  Offline
Lakewood, Colorado
Not sure on that. Mine is the tic toc
Re: Rallye gauge decal sets [Re: runnerrt] #1223270
04/29/12 06:54 AM
04/29/12 06:54 AM
SE Pa.
LimeliteAero Offline
SE Pa.
in a rally gauge set every pointer comes off, when you get your decal set there will be instructions on how to remove the needles from the gauge set.
Re: Rallye gauge decal sets [Re: LimeliteAero] #1223271
04/29/12 12:03 PM
04/29/12 12:03 PM
Western NY
19SuperBee70 Offline
Western NY
As said above only the speedo and clock needles come off in a b body rally dash. The other needles are not removable, and they are very fragile.
I am in the process of doing mine now. What i did for the smaller gauges is grind the two rivets down so I could remove the gauge face and paint. The gauges have a lip, and I couldn't figure out a good way to cover the needle while painting the face. With the fces off you will see how fragile the whole assembly is.
Re: Rallye gauge decal sets [Re: 19SuperBee70] #1223272
04/29/12 02:45 PM
04/29/12 02:45 PM
SE Pa.
SE Pa.
I think you lost a bearing.....
I just went into the shop and removed this needle.
Re: Rallye gauge decal sets [Re: Dougsmopars] #1223273
04/29/12 03:23 PM
04/29/12 03:23 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
The "decal instructions", about halfway down the page of this link, explain about removing the pointers.
http://premiumdashdecals.com/support.htm
Hope this helps.
Re: Rallye gauge decal sets [Re: moparfan53] #1223274
04/29/12 04:36 PM
04/29/12 04:36 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
why paint? The decal covers 100% of the face..and you can get them on without removing the needle.... just slide them in place..
I removed one needle...and it was a PITA...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Rallye gauge decal sets [Re: moparfan53] #1223275
04/29/12 04:51 PM
04/29/12 04:51 PM
They look to be a good company. Anyone used there product? Hate to buy them off ebay to many seconds get porned off on there
Re: Rallye gauge decal sets [Re: Dougsmopars] #1223276
04/29/12 06:29 PM
04/29/12 06:29 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
I bought the set... went on with no issues and look great!
Re: Rallye gauge decal sets [Re: JMCFAN] #1223277
04/29/12 06:49 PM
04/29/12 06:49 PM
Western NY
Western NY
Well, i learned something new. I'll have to take a look at mine. it seemed easier to remove the faces to paint, 10 second of grinding the rivets and they're off. I painted the faces because I'm using white overlays. the black shows through the overlay and makes it look dull.
Re: Rallye gauge decal sets [Re: Dougsmopars] #1223278
04/29/12 08:30 PM
04/29/12 08:30 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've used them on 2 different cars - a 1970 E-body and a 1969 B-body rallye dash . I have no complaints of any kind on either purchase.
This is the 69 B-body set as an example. Clock only is done in this picture, speedo is not.
Re: Rallye gauge decal sets [Re: gtx6970] #1223279
04/29/12 08:31 PM
04/29/12 08:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
closeup.
Re: Rallye gauge decal sets [Re: gtx6970] #1223280
04/29/12 10:42 PM
04/29/12 10:42 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
the odometer set went on nice as well.... huge difference!
Re: Rallye gauge decal sets [Re: gtx6970] #1223281
04/30/12 06:14 PM
04/30/12 06:14 PM
Haveing trouble finding the tach decal. Mine is not a tic toc.I'll post an image as sonn as i figure out how to resize it.
Re: Rallye gauge decal sets [Re: Dougsmopars] #1223282
05/02/12 10:06 AM
05/02/12 10:06 AM
SE Pa.
SE Pa.
Ive never seen that tach...Im pretty sure you wont find a decal for that face.
