Re: Rallye gauge decal sets
[Re: Dougsmopars]
#1223264
04/27/12 11:49 PM
04/27/12 11:49 PM
Posts: 550 Lakewood, Colorado
runnerrt
Lakewood, Colorado
Did mine on my 69 Bee. Not to hard to do,Clean and paint the original face and install your decal. I can post some pictures tomorrow if you like.
1969 Super Bee High School car I got back
2004 Ram 2500
[Re: Dougsmopars]
#1223267
04/28/12 09:13 PM
04/28/12 09:13 PM
runnerrt
Lakewood, Colorado
Clock and speedo are the only one that come off. You need to be careful but they slide off
2004 Ram 2500
[Re: 19SuperBee70]
#1223272
04/29/12 02:45 PM
04/29/12 02:45 PM
Posts: 6,583 SE Pa.
LimeliteAero
SE Pa.
As said above only the speedo and clock needles come off in a b body rally dash. The other needles are not removable, and they are very fragile.
I am in the process of doing mine now. What i did for the smaller gauges is grind the two rivets down so I could remove the gauge face and paint. The gauges have a lip, and I couldn't figure out a good way to cover the needle while painting the face. With the fces off you will see how fragile the whole assembly is.
I think you lost a bearing..... I just went into the shop and removed this needle.
[Re: moparfan53]
#1223274
04/29/12 04:36 PM
04/29/12 04:36 PM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
why paint? The decal covers 100% of the face..and you can get them on without removing the needle.... just slide them in place..
I removed one needle...and it was a PITA...
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: Dougsmopars]
#1223276
04/29/12 06:29 PM
04/29/12 06:29 PM
JMCFAN
New Mexico
I bought the set... went on with no issues and look great!
[Re: gtx6970]
#1223280
04/29/12 10:42 PM
04/29/12 10:42 PM
JMCFAN
New Mexico
the odometer set went on nice as well.... huge difference!
[Re: gtx6970]
#1223281
04/30/12 06:14 PM
04/30/12 06:14 PM
Posts: 2,295 dark side of the moon
Dougsmopars
Haveing trouble finding the tach decal. Mine is not a tic toc.I'll post an image as sonn as i figure out how to resize it.
