Auxiliary fuse box #1222732
04/26/12 07:13 PM
04/26/12 07:13 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I am running an MSD and an electric fuel pump through my ancient bulk head connector. What would it take to put in a small fuse block and run this high-draw stuff through there? Realizing that the battery charging would still be going through the factory fuse block.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Auxiliary fuse box [Re: cdstl] #1222733
04/26/12 07:19 PM
04/26/12 07:19 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
a minimal amount of effort and readily available parts. or are you asking how would you do it? that, my friend would depend on where you wanted to locate this fusebox.
Re: Auxiliary fuse box [Re: mikemee1331] #1222734
04/26/12 07:27 PM
04/26/12 07:27 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I imagine that I would run a 12G wire from the battery side of the alternator into the aftermarket, or junkyard, fuse block. And then wire my accessories into one of the slots. Is that all that there is to it?
Re: Auxiliary fuse box [Re: cdstl] #1222735
04/26/12 07:40 PM
04/26/12 07:40 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i would go a step heavier on the power feed and you would have to decide whether or not this fusebox would be a 'switched on' box or always on. that would be the deciding factor on where to have your power feed come from.
Re: Auxiliary fuse box [Re: cdstl] #1222736
04/26/12 08:20 PM
04/26/12 08:20 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
It would always be hot. I have a switch for the MSD and fuel pump.
Re: Auxiliary fuse box [Re: cdstl] #1222737
04/26/12 10:46 PM
04/26/12 10:46 PM
Alberta
rustbuckett68 Offline
Alberta
I think this is out of a Daytona (?), not sure of the year. I put it into my 84 GMC when I rewired the headlights with larger wires and relays. I pulled the connectors out, and replaced them to my master plan (!), and it worked. Somewhere, I have an auxillary fuse panel off a late 80's B van. Self contained with plug bayonet fuses. I'll try and get a pic, if I remember.
Re: Auxiliary fuse box [Re: cdstl] #1222738
04/26/12 11:52 PM
04/26/12 11:52 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
This looks promising, around $10.
Re: Auxiliary fuse box [Re: cdstl] #1222739
04/27/12 12:58 AM
04/27/12 12:58 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Re: Auxiliary fuse box [Re: Pool Fixer] #1222740
04/27/12 01:00 AM
04/27/12 01:00 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
It's all fed from the starter relay on the firewall, no need to run any current through the bulkhead. 130 amp alternator helps too...
Don't forget the relays
Re: Auxiliary fuse box [Re: Pool Fixer] #1222741
04/27/12 01:02 AM
04/27/12 01:02 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Got the box at West Marine... but Buss make it so I'm sure you could find it somewhere else...
Re: Auxiliary fuse box [Re: cdstl] #1222742
04/27/12 02:11 AM
04/27/12 02:11 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I have a five fuse version of one of those in my Duster from Pep Boys (I think), nice basic fuse block.
MSD recommends its main power and ground wires be run directly to the battery though. This could work for the fuel pump, just be sure to use a relay for safety.
Ride eternal, shiny and chrome
Re: Auxiliary fuse box [Re: DirectSubjection] #1222743
04/27/12 07:53 PM
04/27/12 07:53 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Hey DirectSubjection, what's with the teaser pic?? post a pic of the whole engine bay, it looks pretty sweet!
