Auxiliary fuse box
#1222732
04/26/12 07:13 PM
04/26/12 07:13 PM
Posts: 1,487 STL
cdstl
STL
I am running an MSD and an electric fuel pump through my ancient bulk head connector. What would it take to put in a small fuse block and run this high-draw stuff through there? Realizing that the battery charging would still be going through the factory fuse block.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Auxiliary fuse box
[Re: mikemee1331]
#1222734
04/26/12 07:27 PM
04/26/12 07:27 PM
Posts: 1,487 STL
cdstl
STL
I imagine that I would run a 12G wire from the battery side of the alternator into the aftermarket, or junkyard, fuse block. And then wire my accessories into one of the slots. Is that all that there is to it?
[Re: cdstl]
#1222735
04/26/12 07:40 PM
04/26/12 07:40 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
i would go a step heavier on the power feed and you would have to decide whether or not this fusebox would be a 'switched on' box or always on. that would be the deciding factor on where to have your power feed come from.
[Re: cdstl]
#1222736
04/26/12 08:20 PM
04/26/12 08:20 PM
Posts: 1,487 STL
cdstl
STL
It would always be hot. I have a switch for the MSD and fuel pump.
[Re: cdstl]
#1222738
04/26/12 11:52 PM
04/26/12 11:52 PM
Posts: 1,487 STL
cdstl
STL
This looks promising, around $10.
[Re: cdstl]
#1222742
04/27/12 02:11 AM
04/27/12 02:11 AM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
I have a five fuse version of one of those in my Duster from Pep Boys (I think), nice basic fuse block.
MSD recommends its main power and ground wires be run directly to the battery though. This could work for the fuel pump, just be sure to use a relay for safety.
Ride eternal, shiny and chrome
[Re: DirectSubjection]
#1222743
04/27/12 07:53 PM
04/27/12 07:53 PM
mikemee1331
bethlehem pa
Hey DirectSubjection, what's with the teaser pic?? post a pic of the whole engine bay, it looks pretty sweet!
