Master Cylinder #1222609
04/26/12 03:06 PM
04/26/12 03:06 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Does anyone have a link for info or a step-by-step guide to upgrading from the stock single to double chamber master cylinder on a '66 vehicle w/ wheel drums?
Re: Master Cylinder [Re: jeebis44] #1222610
04/26/12 03:50 PM
04/26/12 03:50 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Mopar Action magazine has covered this before. They may have some articles on their website. Look for "Disc-o-tech".
Re: Master Cylinder [Re: jeebis44] #1222611
04/26/12 07:05 PM
04/26/12 07:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ebooger has covered it in a separate article in mopar action , it's actually pretty easy to do.
Re: Master Cylinder [Re: JohnRR] #1222612
04/26/12 07:26 PM
04/26/12 07:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
amazing what you can find with that little search box at the top of the page https://board.moparts.org/ubbthreads/showflat.php?Number=5679008
Re: Master Cylinder [Re: mikemee1331] #1222613
04/27/12 11:11 AM
04/27/12 11:11 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Thanks for the replies - for 4 wheel drum brakes, is the pressure equal at all 4 corners? Or should there be a front/rear bias?
Re: Master Cylinder [Re: jeebis44] #1222614
04/27/12 11:55 AM
04/27/12 11:55 AM
The pressure would be equal with a simple splitter block. you would use smaller rear wheel cyls to adjust the bias to keep from locking up the rears
