ARP rocker shaft studs?
#1222589
04/26/12 02:00 PM
04/26/12 02:00 PM
Posts: 617 Corvallis,OR
540CUDA
super street
super street
Corvallis,OR
My BB Edelbrocks came with long studs for the oil supply holes but none for the rest, does anyone know a part # for a stud that will fit. Ive looked at ARP catalog and they dont have "universal" use studs listed.
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
Re: ARP rocker shaft studs?
[Re: 540CUDA]
#1222591
04/26/12 06:30 PM
04/26/12 06:30 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I should have them in stock...will advise
RIP Monte Smith
[Re: Stanton]
#1222594
04/26/12 11:53 PM
04/26/12 11:53 PM
Posts: 5,875 communist bloc of new jersey
jamesc
While we're talking about these ... how tight do they get screwed into the head and do they get lubed first?
finger tight is fine though the newer arp studs are broached for a hex key so i snug them a little more to help keep them from backing out when the nut is loosened. i lubricate pretty much all threaded fasteners.
i also use flanged nuts and hardened washers. i have a friend that owns an automotive machine shop so i have a good supply of used flanged nuts from the stock type rods he reconditions that have aftermarket bolts in them.
[Re: jamesc]
#1222595
04/29/12 02:17 AM
04/29/12 02:17 AM
Posts: 1,760 Port Alberni, British Columbia
MoparDonny
I have the stud kit from Hughes Engines on mine!! 12 point nuts with washers. I believe I spent about 4 years (or 3 nights)filing the hold-downs to get the rockers set up . I got their side shim kit also.
