Carter AVS Strip kit #1222561
04/26/12 11:56 AM
04/26/12 11:56 AM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
Are the jets and rods from the new Edelbrock AVS carbs interchangable with the older AVS carbs. Have a 69 GTX going on a chassis dyno and would like to have some jets and rods for tuning.
Lee
Re: Carter AVS Strip kit [Re: Lee] #1222562
04/26/12 12:19 PM
04/26/12 12:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can use them but they are not the same.
The original AVS rods are 3 step , the Ebrocks are 2 step as used in the earlier AFB's. You'll need to change the tin cover over the step up piston to a flat one or fill the dome of the stock AVS covers .
Re: Carter AVS Strip kit [Re: JohnRR] #1222563
04/26/12 02:18 PM
04/26/12 02:18 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What John said. The EB kits work just fine if you swap the metering rod covers.
