axle info?69 B Body pinion offset? #1222302
04/25/12 05:46 PM
04/25/12 05:46 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
what would be the pinion measurement from axle flange from any side?[offset dana 60]
Re: axle info?69 B Body pinion offset? [Re: Clanton] #1222303
04/25/12 05:54 PM
04/25/12 05:54 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Make the drivers side axle tube 1.375" longer than the pass side to get your offset. The actual pinion offset is about 1 3/16" IIRC
Re: axle info?69 B Body pinion offset? [Re: RobX4406] #1222304
04/25/12 06:08 PM
04/25/12 06:08 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you!i am double checking some measurements that i am having work done on.
Re: axle info?69 B Body pinion offset? [Re: Clanton] #1222305
04/25/12 06:46 PM
04/25/12 06:46 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
BTW,the housing width numbers on that chart for an A body are incorrect. It's supposed to be 52 and 5/8, IIRC.
Re: axle info?69 B Body pinion offset? [Re: forphorty] #1222306
04/25/12 07:07 PM
04/25/12 07:07 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks that info is from the tech archive her on moparts.
Re: axle info?69 B Body pinion offset? [Re: Clanton] #1222307
04/25/12 08:58 PM
04/25/12 08:58 PM
RobX4406 Offline
RobX4406  Offline
And it's been requested to pull that POS chart down for almost as long as I've been here. The chart has caused more than a few to shorten rears to the wrong length.
Not only is the A rear length wrong, the B rear length is not correct either. Yet it still stays up here to cause issues... very helpful resource... NOT!
Want correct...
http://www.moparts.org/Tech/Archive/axle/16.html
Re: axle info?69 B Body pinion offset? [Re: RobX4406] #1222308
04/25/12 09:48 PM
04/25/12 09:48 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
