Mopar engines came with steel gaskets everywhere, even under the thermostat housing.
You have disassembled far enough. Don't even think about removing the heads. The rat poison will get blown out the exhaust upon fireup.
I've started many an engine after longer than that sitting in a field or under a tree. It's a 318, stockish rebuild. Nothing can hurt it.
Here's what I'd do:
Pull rocker assemblies, pushrods and lifters, keeping in order.
Pull spark plugs and squirt a couple of squirts of 2-cycle engine oil in each hole. Turn the engine over a couple of times slowly to distribute the oil.
Replace spark plugs.
Get as much cam assembly lube on the cam and bottom of the lifters, oil on the sides as you replace them.
Put assembly lube on each end of the pushrods as you install them.
Put assembly lube on the valve stem tips.
Oil the valve stems through the springs.
Install rocker assemblies, torquing carefully.
Install rocker covers using your favorite goop to help seal the gaskets.
If using the steel intake gaskets, apply a thin film of your favorite goop to each side before insallation.
Clean the end rails and mating manifold places.
Throw the end seals away.
Apply an appropriate-sized bead of silicone or "The Right Stuff" to the end rails of the block, a little more on each end in the "corner".
Set the intake in place. If you used the right stuff, torque it down. If you used silicone give it a few hours.
Now your engine is ready to go into a car. After it is installed and the pan is full of oil, you can prime the oil system with a drill and the proper tool.
Good Luck!
R.
