How much can you tighten Valve Lash? #1222165
04/25/12 03:04 PM
04/25/12 03:04 PM
Nanaimo, B.C.
GwaiiEagle Offline OP
Mannix
Mannix
Nanaimo, B.C.
Magnum 282 solid, 282 adv, 236 at 50, .495 stock lift, .528 with my 1.6 rocker arms.
It is said that you can tighten lash to see if the engine likes it.
Question is how much can you safely tighten it? Magnum Cams must have a mild ramp speed.
Re: How much can you tighten Valve Lash? [Re: GwaiiEagle] #1222166
04/25/12 03:18 PM
04/25/12 03:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
None in my opinion, I'd run what ever lash the cam card say's. I wouldn't deveate anymore than .005" from the proper lash.
Re: How much can you tighten Valve Lash? [Re: GwaiiEagle] #1222167
04/25/12 09:27 PM
04/25/12 09:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Generally, you can tighten them up as much as you want but making sure that the valve is closing. You probably don't want to go that far. However, loosening them is a bit different. The looser they get, the harder the cam slaps the lifter after the lash is taken-up. One of the cam manufactures recommends no more than 0.004" looser than spec for their agressive lobes, FWIW. I've run as loose as 0.034" on a 0.026" spec.on an old style cam. Ran well, but sounded like a tin can of marbles.
Re: How much can you tighten Valve Lash? [Re: GwaiiEagle] #1222168
04/25/12 10:51 PM
04/25/12 10:51 PM
I have been told and used the 25% rule, if it is suppose to be set at .024 hot then .006 tighter and no more than .004 looser is what I try. Same thing if it is a tight lash cam, .016 hot then tighten up to .012 max and to .020 looser max
Re: How much can you tighten Valve Lash? [Re: GwaiiEagle] #1222169
04/25/12 11:49 PM
04/25/12 11:49 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
If I am remembering correctly,the Magnum lobes were designed so you can vary the lash more than most. I think they used to tell you anywhere from .020 to .035 was okay. I will have to check and get back to you before you go too far.
Keith
Re: How much can you tighten Valve Lash? [Re: Dunnuck Racing] #1222170
04/26/12 12:05 AM
04/26/12 12:05 AM
IN
ahy Offline
ahy  Offline
IN
Rule of thumb, .004"-.005" variation from spec. Agree it depends on the lobes. My tight lash fast rate cam probably would be on the low side of tolerence for variation. If you vary much, everything needs to be "right" including measurement technique to prevent a big "oops".
Re: How much can you tighten Valve Lash? [Re: GwaiiEagle] #1222171
04/26/12 10:58 AM
04/26/12 10:58 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
??? I ran a MP 528 solid at 22-24 (cold). It seemed to run better than the factory recommened 28-32
Coming soon!!!!
Re: How much can you tighten Valve Lash? [Re: Mr.Yuck] #1222172
05/04/12 05:50 PM
05/04/12 05:50 PM
Frederick, MD
moparguy1967 Offline
Frederick, MD
Not to hi jack this tread, but Im running the 284/528 solid in my car. Do you feel that running it at 22-24 will hurt the valve train at all on a street car??
Re: How much can you tighten Valve Lash? [Re: moparguy1967] #1222173
05/04/12 06:11 PM
05/04/12 06:11 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I run the MP 528 cam and set the lash 20/22 cold. I run Stealth heads so the lash gets bigger as the engine warms up. I don't think I'd set the lash that tight with iron heads because the lash gets smaller with heat. 28/32 cold with iron heads would be around 26/30 with iron heads once it's warm and that's about what I have when the ally heads heat up.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: How much can you tighten Valve Lash? [Re: GwaiiEagle] #1222174
05/04/12 09:25 PM
05/04/12 09:25 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the lash on this cam can be varied between .015"-.030" per comp cams. i would use .016" hot as the minimum with a 1.6 rocker.
Re: How much can you tighten Valve Lash? [Re: moparguy1967] #1222175
05/04/12 10:42 PM
05/04/12 10:42 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I had iron heads and it seemed to work for me. You can always try 24/28 for starters
Re: How much can you tighten Valve Lash? [Re: Mr.Yuck] #1222176
05/04/12 10:54 PM
05/04/12 10:54 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You want to increase the lash on a 1.6 rocker versus a 1.5 anyway. I imagine the engine would "like" any decrease in lash since that is essentially increasing lift and duration. Personally I'd run what the manufacturer recommends and if you want more power, find it somewhere else.
Re: How much can you tighten Valve Lash? [Re: Stanton] #1222177
05/05/12 12:56 AM
05/05/12 12:56 AM
I have always thought "tight lash" cams were just another way to claim better numbers under the curve. Another cam sales device for sure! ( or every cam on the planet would be one!) I have seen race engines run and sound just fine but be much slower( several tenths) when lash was too tight--as in the valves never really close and "seal in" that lick. You have to get enough lash so that they really have a chance to close at the RPM you are racing at. I would bet my shop that on a dyno you would see very little diff going with more lash but too little can kill power. It is all bout RPM as well--a street engine is not the same as a unit buzzing 7500 RPM--Component weight plays even more as RPM goes up--Swapping to Titanium retainers can often make it feel like you changed engines in a drag car--If you were short on installed height like some small blocks even more so. It is a balancing act and lash plays a very small part as long as you have enough. There is no way to explain how much you can learn on a dyno in a year--it will dispell lots of BS "conventional wisdom" in a HURRY.
Light weight valvetrain GOOD, Belt Drives GOOD, stiff pushrods GOOD, enough spring pressure to control it all GOOD Chasing valve lash all over the place--a waste of time IMO. I have seen Bob Reed lash a Hemi in staging so fast it would make your head spin and he did NOT get them within a few thou--he lashed 'em and raced 'em--in other words--made darn sure it HAD some then went to it!!! Ya'll should to--and...in a drag engine do intake and Ex the same--it is EASIER and who thinks that in 6-10 seconds an ex valve will be hot enough to change the lash enough to make one millionth of a second diff?
