Re: Voltage regulator probs
[Re: moparcanuk]
#1222133
04/25/12 07:24 PM
04/25/12 07:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I assume this is the single field connection system?
I had the same problem years ago with my 64 300. The wire from the terminal to the coil (inside the box) would blow. I ended up replacing that wire with a thicker one that never blew and I never had and problems after that.
[Re: Supercuda]
#1222134
04/25/12 07:43 PM
04/25/12 07:43 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
if the fuse is 'over-rated' for the size wire you are using the fuse would never blow. it could also be the tunes in your MP3 player .
[Re: mikemee1331]
#1222135
04/26/12 12:21 AM
04/26/12 12:21 AM
Posts: 905 SD
zrxkawboy
SD
A short in the field circuit (either alternator or wiring) can take out a regulator.
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#1222137
04/26/12 09:21 PM
04/26/12 09:21 PM
Posts: 1,522 Orleans, Ontario
moparcanuk
Orleans, Ontario
Bingo!! I put a fuse between the alternator and voltage regulator and blew it within 2 minutes. The alternator is definitely shorting out periodically.
[Re: moparcanuk]
#1222138
04/26/12 11:22 PM
04/26/12 11:22 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Stock 69 440 GTX. 3 voltage regulators in 3 weeks. Each time, one of the two wires inside was vaporized. I leave my MP3 player plugged into the lighter socket. I would assume that if that was the problem a fuse would blow. Any ideas?
Have you sanded the bottom of the voltage regulator down to bare metal.. It needs a solid ground connection..
Just my $0.02...
