Voltage regulator probs #1222132
04/25/12 01:38 PM
04/25/12 01:38 PM
Orleans, Ontario
moparcanuk Offline OP
Orleans, Ontario
Stock 69 440 GTX. 3 voltage regulators in 3 weeks. Each time, one of the two wires inside was vaporized. I leave my MP3 player plugged into the lighter socket. I would assume that if that was the problem a fuse would blow. Any ideas?
Re: Voltage regulator probs [Re: moparcanuk] #1222133
04/25/12 07:24 PM
04/25/12 07:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I assume this is the single field connection system?
I had the same problem years ago with my 64 300. The wire from the terminal to the coil (inside the box) would blow. I ended up replacing that wire with a thicker one that never blew and I never had and problems after that.
Don't be the exception.
Re: Voltage regulator probs [Re: Supercuda] #1222134
04/25/12 07:43 PM
04/25/12 07:43 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if the fuse is 'over-rated' for the size wire you are using the fuse would never blow. it could also be the tunes in your MP3 player .
Re: Voltage regulator probs [Re: mikemee1331] #1222135
04/26/12 12:21 AM
04/26/12 12:21 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
A short in the field circuit (either alternator or wiring) can take out a regulator.
It's Swifty! Swifty, you toad sucker!
Re: Voltage regulator probs [Re: zrxkawboy] #1222136
04/26/12 11:32 AM
04/26/12 11:32 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Oh yeah, the field wire or even inside the alt is trash.
CHINESE PARTS! junk
Re: Voltage regulator probs [Re: zrxkawboy] #1222137
04/26/12 09:21 PM
04/26/12 09:21 PM
Orleans, Ontario
Orleans, Ontario
Bingo!! I put a fuse between the alternator and voltage regulator and blew it within 2 minutes. The alternator is definitely shorting out periodically.
Re: Voltage regulator probs [Re: moparcanuk] #1222138
04/26/12 11:22 PM
04/26/12 11:22 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Have you sanded the bottom of the voltage regulator down to bare metal..
It needs a solid ground connection..
Just my $0.02...
