Thermoquad Air Door Spring Adjusting Tool
#1222098
04/25/12 10:08 AM
04/25/12 10:08 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I want one of these but I'll file down an old screwdriver before I spend 60 bucks!!! Anybody know of a more reasonably priced one? Googling didn't help.
Re: Thermoquad Air Door Spring Adjusting Tool
[Re: UCUDANT]
#1222104
04/26/12 10:28 AM
04/26/12 10:28 AM
Posts: 75,064 U.S.S.A.
JohnRR
U.S.S.A.
Scott's admiring yer tool
[Re: JohnRR]
#1222106
04/26/12 10:51 AM
04/26/12 10:51 AM
Commando1
The proctologist of fiberglass makes one , not sure if he still is selling them though.
Haven't seen him around for a long time. Did he lose his library privileges???
[Re: Commando1]
#1222107
04/26/12 11:02 AM
04/26/12 11:02 AM
Challenger 1
Cincinnati, Ohio
And his Moparts privileges!
[Re: Commando1]
#1222109
05/01/12 01:55 AM
05/01/12 01:55 AM
Posts: 5,270 Missouri
MY340
Missouri
I used to make them with a 3-4" long 1/4" nipple, 1/4" pipe tee and two short 1/4" nipples for the handle. Drill a hole in the tee for your thin blade screwdriver to go thru and file/grind the two bumps to fit the locking screw on the TQ air door.
Worked great at hardly any cost. Hardware store or McMaster-Carr will have the black iron pipe fittings.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: DaytonaTurbo]
#1222111
05/01/12 09:32 AM
05/01/12 09:32 AM
Commando1
I must be the only guy who never had trouble adjusting with just a pair of flat screwdrivers!
I spent good money to have Scott Smith restore mine. I'm not about to muck it up because I'm too cheap to spend 15 bucks on the proper tool. If you got an old TQ, yah, then I can see it.
PS: Your reply contains a dangling non-participial modifier.
