489 8 3/4 Gear Case #1222095
04/25/12 09:46 AM
04/25/12 09:46 AM
TN
65racer Offline OP
2009 IHRA World Champion
65racer  Offline OP
TN
Have a ??? for you guy"s that run the 489
case, does the pinion have the thick washer
behind the pinion bearing like the 742 case does?
It has been so long since I tried to set one
of those up, I can't remember.
Also does rateck still make the steel sleeve to
eliminate the crush sleeve, when setting one up
for a drag car?
Thanks in advance
Re: 489 8 3/4 Gear Case [Re: 65racer] #1222096
04/25/12 09:50 AM
04/25/12 09:50 AM
tboomer Offline
tboomer  Offline
Dave...Dr.Diff had that crush sleeve eliminator. I bought one from him when I had the 8.75....
Re: 489 8 3/4 Gear Case [Re: tboomer] #1222097
04/25/12 10:43 AM
04/25/12 10:43 AM
Guitar Jones Offline
The 489 case uses a thin shim.
