front wheel play #1221959
04/24/12 11:41 PM
04/24/12 11:41 PM
lake county, ca
lake71383 Offline OP
lake county, ca
Ok guys, I search for an answer to my dumb question but couldn't find one. So today I redid the wheel bearing in my satellite and when I got done I moved the wheels side to side no movement good and then up and down and it has 1/4" of play. If I tighten down the spindle nut it goods away, but any tighter then it is right now and the wheel will not spin freely and I know on newer cars any play is bad is this normal for a satellite or is something wrong. It also has front drum if that matter. Thank You for the help.
Re: front wheel play [Re: lake71383] #1221960
04/25/12 12:35 AM
04/25/12 12:35 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
There should be no play up and down. Did you replace the bearings, or just clean and repack them??
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: front wheel play [Re: Prodart440] #1221961
04/25/12 12:50 AM
04/25/12 12:50 AM
lake county, ca
lake county, ca
I check them for wear and then clean the and repacked them. The resone I did this is because I took the car around the block and when I got home I had grease all over the wheel so I pulled the dust cap and grease was as thin as 30w motor oil and ran out.
Re: front wheel play [Re: lake71383] #1221962
04/25/12 12:53 AM
04/25/12 12:53 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I would try replacing them. Sounds like they are worn out. I am doing the same on my cuda. 1/16" of play up and down on the passenger side. I decided to just replace them.
Aaron
68 Coronet 440
Re: front wheel play [Re: Prodart440] #1221963
04/25/12 01:15 AM
04/25/12 01:15 AM
lake county, ca
lake county, ca
Yeah I think all give that a try.
Re: front wheel play [Re: lake71383] #1221964
04/25/12 01:31 AM
04/25/12 01:31 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
measure the spindle dia. where the bearing inner race sits, front to back and top to bottom .
you may find it is out of round ,if so replacing bearings aint gona help !
Re: front wheel play [Re: calrobb2000] #1221965
04/25/12 01:41 AM
04/25/12 01:41 AM
lake county, ca
lake county, ca
Thanks I'll measure the spindle
