no choke really give you more power? #1221701
04/24/12 03:20 PM
04/24/12 03:20 PM
United states wisconsin
bigblockbryan Offline OP
okay im running my buddies holley double pumper wich he has no choke flap he claims its gives it a extra 20 hp. Is this true just curious i really hate not having a choke when its cold out in the morning if he ever wants his carb back, i probably will have one with a choke lol
Re: no choke really give you more power? [Re: bigblockbryan] #1221702
04/24/12 03:29 PM
04/24/12 03:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is your buddy a brand X owner ??? 20hp increase ... it does increase the air flow , but to the tune of 20HP ????
Re: no choke really give you more power? [Re: JohnRR] #1221703
04/24/12 03:39 PM
04/24/12 03:39 PM
yea hes a chevy guy i thought he was on crack i understand how a engine works and it just seemed un realstic i think my car will have a choke when i buy one since its more of a street car then anything else
Re: no choke really give you more power? [Re: bigblockbryan] #1221704
04/24/12 05:52 PM
04/24/12 05:52 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
I remove choke horn on this edelbrock 750.
I don't know if this modification give some horsepowers but I'm sure I don't lost any...
Re: no choke really give you more power? [Re: STROKIE] #1221705
04/24/12 06:33 PM
04/24/12 06:33 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Yea,, he's smoking something and its not rubber...
I am truckless..
Re: no choke really give you more power? [Re: 340SHORTY] #1221706
04/25/12 06:05 AM
04/25/12 06:05 AM
kinda thought so those chevy guys always got some odd ideas the craziest idea hes had is me getting a chevy lol i like older pontiacts but when it comes down to it id rather trade my money for another mopar
Re: no choke really give you more power? [Re: bigblockbryan] #1221707
04/25/12 08:42 AM
04/25/12 08:42 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Amount of gain ( IMO) would be more effected by the level of build on the engine.
A stock or semi stock engine,,, I tend to think would see very little, if any, gain. Yet a high horsepower engine might benefit from the modification more.
Re: no choke really give you more power? [Re: bigblockbryan] #1221708
04/25/12 08:43 AM
04/25/12 08:43 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
what did he do? simply remove the choke plate but leave the tall horn that holds the choke plate?
if that's all he did, then no, I don't think he gained any hp. maybe 2 or 3 from less turbulence through the venturies in the carb.
if it's a carb that was designed without a choke like a 750HP that was fabricated without a choke, it might make 10-15 hp more? Has anyone done a back to back dyno test to show the difference here? It'd be neat to see, a mechanical secondary 750 holley with a choke hooked up and working, and a mechanical secondary 750 holley without a choke.
**Photobucket sucks**
Re: no choke really give you more power? [Re: 70Cuda383] #1221709
04/26/12 05:30 AM
04/26/12 05:30 AM
its a 750 with proform main body his motor is a 350 stoked to a 383 dynoed at 507 hp my motor is pretty mild
Re: no choke really give you more power? [Re: bigblockbryan] #1221710
04/26/12 07:13 AM
04/26/12 07:13 AM
Central NC
gch Offline
gch  Offline
Central NC
The proform main body has the contoured air entry like an HP series Holley.IMO it is worth a few cfm over a standard main body with a choke horn.On a mild motor you may or may not notice some improved throttle response but on a higher hp/rpm motor it is worth some power over a standard main body with a choke tower provided the engine can use the extra cfm.
You are getting down to race car stuff for the last couple of thousands or tenth at the track for ACTUAL need.
Re: no choke really give you more power? [Re: gch] #1221711
04/26/12 07:22 AM
04/26/12 07:22 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I think it depends on the motor and on the carb you choose. If the carb is on the small side of what the motor wants yes you can pick up some power. The Carter AFB's were a bit on the small side of what they were advertized. The Thermoquad picks up quite a few cfm by removing the choke and linkage. Dave
Re: no choke really give you more power? [Re: quickd100] #1221712
04/26/12 10:24 AM
04/26/12 10:24 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Back in the 90s one of the car mags did a thing on a dyno for free hp and one of them was removed the choke flap horn was stil just took out the flap made 18 hp differance back to back on the dyno think removing the fan made like somewhere around 20-25 hp and ele water pump was lile 25 hp they changed one thing at a time made a pull then put it back and tried something differnt was pretty coolo
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: no choke really give you more power? [Re: gtx6970] #1221713
04/26/12 11:44 AM
04/26/12 11:44 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
