Re: no choke really give you more power?
[Re: STROKIE]
#1221705
04/24/12 06:33 PM
04/24/12 06:33 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Yea,, he's smoking something and its not rubber...
I am truckless..
[Re: bigblockbryan]
#1221708
04/25/12 08:43 AM
04/25/12 08:43 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
what did he do? simply remove the choke plate but leave the tall horn that holds the choke plate?
if that's all he did, then no, I don't think he gained any hp. maybe 2 or 3 from less turbulence through the venturies in the carb.
if it's a carb that was designed without a choke like a 750HP that was fabricated without a choke, it might make 10-15 hp more? Has anyone done a back to back dyno test to show the difference here? It'd be neat to see, a mechanical secondary 750 holley with a choke hooked up and working, and a mechanical secondary 750 holley without a choke.
**Photobucket sucks**
