Grinding/knocking from diff under deceleration
#1221284
04/23/12 06:00 PM
04/23/12 06:00 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I suspect the pinion depth is messed up on my 8.75 rear, but I figured I’ll solicit some opinions as I get ready to pull it.
Road Runner has a ‘489 case 3.55 sure grip in it. It makes an occasional knocking noise while coasting/ decelerating. It doesn’t always do it, but it’s quite frequent, and it definitely emanates from the rear. It also has a vehicle speed dependent harmonic vibration.
I figure if it were a bearing issue that I’d have issues under acceleration or cruise as well.
It's done this pretty much from the day I got the car two years ago. I’ve had so many other issues with which to contend that I’ve just let it go up to this point.
Now I’ll be swapping out the center section for my trusty set of 2.76’s later this week in preparation for the Power Tour, so any visually obvious issue will be revealed. I half-expect to find chunks of pinion teeth in the housing.
Needless to say, before those 3.55s go back in, I want to get them straightened out.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Grinding/knocking from diff under deceleration
[Re: Pacnorthcuda]
#1221287
04/23/12 06:15 PM
04/23/12 06:15 PM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
Your 489's crush sleeve may have lost its preload, allowing pinion slop.
Exactly. Any way you look at it it needs to be taken apart and inspected.
[Re: 268RTs4ME]
#1221289
04/23/12 06:49 PM
04/23/12 06:49 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
When you accelerate the pinion is trying to push out the front of the housing & the load is carried by the large inner pinion bearing.... When you decelerate the pinion is being sucked into the ring gear... The small bearing is trying to keep it in position.... If the preload backs off the pinion rides to deep & can actually chew on the carrier.... When you pull it apart you'll likely see gear marks on the carrier....
[Re: 1_WILD_RT]
#1221290
04/23/12 08:07 PM
04/23/12 08:07 PM
471Magnum
Space Station #5
I'll pulling it tomorrow night, so we'll know soon enough.
-Jim
[Re: 268RTs4ME]
#1221291
04/23/12 08:23 PM
04/23/12 08:23 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Possibly the shaft that slides through your spider gears is sliding out every now and then and hitting your pinion,had that happen to me one time, no noise until i decelerated, check it out, the little bolt could have snapped that holds the shaft in.
Just an FYI , the spider gear shaft is heald in place by a short dowel pin in the cone type sure grip ... assuming that is what this one has.
[Re: JohnRR]
#1221292
04/23/12 08:44 PM
04/23/12 08:44 PM
471Magnum
Space Station #5
No idea what SG is in there, but it's working and locks pretty aggressively. Hopefully what ever it is still useable or re-buildable.
-Jim
[Re: 268RTs4ME]
#1221293
04/23/12 09:05 PM
04/23/12 09:05 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
that happened to me on my old 489 case...the spider cross shaft walked out on me
[Re: patrick]
#1221294
04/23/12 09:07 PM
04/23/12 09:07 PM
JohnRR
U.S.S.A.
I had a cone with a broken dowel once, but what kept it from walking out was the fact that the spider gear WELDED itself to the shaft
[Re: 268RTs4ME]
#1221298
04/24/12 02:44 PM
04/24/12 02:44 PM
JohnRR
U.S.S.A.
Thats just what I said. The shaft is probably sliding out. Because dow pin or bolt is broke.
I was just letting you know that it's a DOWEL PIN , the factory Borg Warner cone type in an 8.75 does not have a death bolt .
[Re: 471Magnum]
#1221300
04/25/12 10:44 PM
04/25/12 10:44 PM
471Magnum
Space Station #5
Got the 3.55s out tonight. No obvious carnage, but I'm not done inspecting them.
-Jim
[Re: 471Magnum]
#1221301
04/26/12 10:28 AM
04/26/12 10:28 AM
JohnRR
U.S.S.A.
Cone or clutch type suregrip ?
[Re: 471Magnum]
#1221303
04/26/12 11:11 AM
04/26/12 11:11 AM
JohnRR
U.S.S.A.
Cone.
If you can't see anything visual you will probably have to disassemble it to see if something is broken inside , same would hold true for a clutch type.
How did the oil look ?
