17 or 18" steel wheels with dog dish hub caps.
#1220865
04/23/12 01:57 AM
04/23/12 01:57 AM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
Has anyone ever thought of using 17 or 18 inch steel wheels that look like the old 15" steelies? Do they even exist? I would love to run some 17's on the front of my car so I can run big brakes and benefit from better tire selection but I want it to look stock.
Thanks!
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: 17 or 18" steel wheels with dog dish hub caps.
[Re: astjp2]
#1220868
04/23/12 11:13 AM
04/23/12 11:13 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Stockton Wheel Top of a Google search. "under new ownership", May be why you couldn't find them. I looked into getting some cop wheels done in 17", it was spendy and the are very HEAVY. HTH, Steve
[Re: 69charger440_6pa]
#1220875
04/23/12 02:48 PM
04/23/12 02:48 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Place I buy some aluminum outers from (and who also make steel ones) is just making some 20" steel wheels to use a Chevy ralley cap. They had some solid centers made up and cut the windows in it to look like a ralley. They weight a TON.. (but it's what the customer wanted which is why they did it) Oh, and the proportions do look odd as well with the small center cap in the middle of such a large area. My 18" x 10" aluminum wheels only are around 19 pounds each, I think I will stick with that over tank wheels.
#1220877
04/23/12 07:28 PM
04/23/12 07:28 PM
Posts: 1,884 Tracy CA
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
How have you been Scott? I picked up that 68 from you back in 02-03 or something like that. You get that challenger going?
Oh hey!! Small world!! I'll send you a PM!
[Re: ahy]
#1220879
04/23/12 09:51 PM
04/23/12 09:51 PM
OzHemi
Garden Grove, CA
Carlise (Carlise wheel that is...) who I buy alot of steel outers from make a few different 17" steel outers. Thier customer service is terrible is the only problem (I cringe every time I have a big order to place, but they have a captive market), but I do have thier sizes handy.. they do a couple different ones. A 17" standard is 15.470" ID A 17" custom is 14.228" ID So obviously the standard are going to use a larger center than a normal 15" wheel so you would get more brake clearance that way. The 20" steel outers are done by another company I deal with...I think they might do 17's and perhaps 18's as well. Don't know thier center ID sizes though off hand on the 20" ones at least.
