PCV,How do I get this piece off the valvecover?? #1220613
04/22/12 07:11 PM
04/22/12 07:11 PM
S.e. lower MIch..
66droptop Offline OP
S.e. lower MIch..
How do I get this black piece off the valvecover to get the pcv off.There is a small baffell inside the cover right where the pcv is..
Re: PCV,How do I get this piece off the valvecover?? [Re: 66droptop] #1220614
04/22/12 07:22 PM
04/22/12 07:22 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
isn't there a tang that aligns with a slot on the cover?
Re: PCV,How do I get this piece off the valvecover?? [Re: 66droptop] #1220615
04/22/12 07:25 PM
04/22/12 07:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It should pull straight off...probably stuck from paint/rust.
Re: PCV,How do I get this piece off the valvecover?? [Re: John_Kunkel] #1220616
04/23/12 12:16 AM
04/23/12 12:16 AM
Twist it as you try to raise it up to unscrew it away from the valve cover, there a tight fit to start with
Re: PCV,How do I get this piece off the valvecover?? [Re: Cab_Burge] #1220617
04/23/12 08:27 PM
04/23/12 08:27 PM
S.e. lower MIch..
S.e. lower MIch..
With a little prying it finally popped off.Thanx guys for the info....
Re: PCV,How do I get this piece off the valvecover?? [Re: 66droptop] #1220618
04/26/12 08:57 PM
04/26/12 08:57 PM
S.e. lower MIch..
S.e. lower MIch..
So I went shopping for a new PCV at the local shop and all showed the wrong one.So onto Yearone,,,$97.99..Are you ^**#@*&^ kidding me...Is this my only option or can I spray the heck out of the old one..The old one still rattles but is dirty..Don't know for sure if it has been replaced.I have had the car 10 years and I haven't...
Re: PCV,How do I get this piece off the valvecover?? [Re: 66droptop] #1220619
04/26/12 09:12 PM
04/26/12 09:12 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
shoot some carb cleaner through it and pop it back on. the rattle is the check ball which only allows one way airflow (out of the cover) and if it still rattles, it's good!
Re: PCV,How do I get this piece off the valvecover?? [Re: mikemee1331] #1220620
04/26/12 09:16 PM
04/26/12 09:16 PM
hooziewhatsit Offline
Or just get a cheap generic one, possibly with a new grommet to make it fit the valve cover. If it's not critical that it looks original...
Re: PCV,How do I get this piece off the valvecover?? [Re: hooziewhatsit] #1220621
04/26/12 09:19 PM
04/26/12 09:19 PM
S.e. lower MIch..
S.e. lower MIch..
I must look like the one above.It sets in the black part.The ones in the part stores are the push on type.
I might just clean this one up....
Re: PCV,How do I get this piece off the valvecover?? [Re: 66droptop] #1220622
04/26/12 10:21 PM
04/26/12 10:21 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
That is just a cover, pull it off, see below. Tim
http://www.amazon.com/Stant-10098-Oil-Fi...id=IS5AB8QP9KOM
Re: PCV,How do I get this piece off the valvecover?? [Re: 66droptop] #1220623
04/27/12 08:50 AM
04/27/12 08:50 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
I cleaned a plastic pcv and a "HEMI" valve cover breather with carb cleaner last summer for my Duster. I pulled them off a set valve covers my father used to have on his car. They both had been sitting for a couple years and I had to put a lot of cleaner through the breather filter to get it clean (the pcv didnt take much). The pcv actually has a Pentastar logo on it. Any way, they are still functioning fine.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: PCV,How do I get this piece off the valvecover?? [Re: 66droptop] #1220624
04/27/12 10:51 AM
04/27/12 10:51 AM
Yonkers N.Y
GTSfanatic Offline
GTSfanatic  Offline
Yonkers N.Y
http://www.ebay.com/itm/63-69-Mopar-A-B-...eb0&vxp=mtr
1968 Dart GTS 340 Auto...White, Red Int
Re: PCV,How do I get this piece off the valvecover?? [Re: GTSfanatic] #1220625
04/27/12 11:04 AM
04/27/12 11:04 AM
PA
BTTG Offline
BTTG  Offline
PA
Bill is always helping folks out here on MOPARTS
http://www.ebay.com/itm/Mopar-resto-PCV-...=item35b5c54895
