carb tuning ??? #1220082
04/21/12 09:37 PM
04/21/12 09:37 PM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
using and A/F meter my idle is at 18-20, I only have the screws out one turn, other question is whats the best # to look for in the upper RPM range? race motor C-12 fuel, Im just testing parked for now but im getting a 10-11 at 4K, carb is a Holley 950 HP, seemed to think it was 12.5 range, any input would be great, as you can tell im just learning this stuff,
Thanks Mike
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: carb tuning ??? [Re: Stroker Scamp] #1220083
04/21/12 11:47 PM
04/21/12 11:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My 470 big-block likes bet. 13.8-14-2 at idle and my wot on the street was bet. 12.5-12.7 when I just ran my best and this is w/VP-100 unleaded at the pump.
Re: carb tuning ??? [Re: Stroker Scamp] #1220084
04/21/12 11:57 PM
04/21/12 11:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
Mike, I shoot for 14.2 to 15.6 at idle and around 13,8 to 14.8 on part throttle cruise, 12,8 to 13.3 at WOT Best thing is to tune for MPH at the track and watch the spark plug, once you get the best results then look at the AFR readings No two motors will like the absolute same readings
Re: carb tuning ??? [Re: Stroker Scamp] #1220085
04/22/12 12:48 AM
04/22/12 12:48 AM
SoCal
Brian Hafliger Offline
SoCal
Thanks Mike
Idle screws out 2-2 1/2 turns, block rear power valve and start with 87, 2.5 PV in front and 77 jet.
I recommend .035 squirters, and blue pump cams front and rear. Make sure you crack the rear throttle blade enough to let air by the blades. OOTB they are seated in the bores and won't properly allow idle adjustments.
A 950 is just too small for that engine though IMO...
Brian
Brian Hafliger
Re: carb tuning ??? [Re: Brian Hafliger] #1220086
04/22/12 01:16 AM
04/22/12 01:16 AM
pacific northwest
pacific northwest
Thanks Mike
Brian
currently running 84 squared no power valves, pretty sure 35 for squirters, think i have a cam kit, boy i should have done this long ago,,, brian wont turning it out to 2 1/2 fatten up the idle?
Re: carb tuning ??? [Re: Stroker Scamp] #1220087
04/22/12 01:54 AM
04/22/12 01:54 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
u could drop down ur idle air bleeds about 4 sizes. that should make the scews about 1 1/2 out. that will clean up the idle some.
Re: carb tuning ??? [Re: rickraw] #1220088
04/22/12 11:28 AM
04/22/12 11:28 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I tune the idle with a vaccum gauge
Re: carb tuning ??? [Re: sshemi] #1220089
04/22/12 03:04 PM
04/22/12 03:04 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
If you have a cam with a lot of duartion then using an O2 meter at idle is useless. My O2 meter says 16:1 at idle but realistically is around 13.
If you do a lot of street driving you will need to get a PV and jet the primaries down 6 jet sizes. Otherwise you will be crusiing at 12 afr....not good.
Re: carb tuning ??? [Re: Big B] #1220090
04/24/12 12:25 AM
04/24/12 12:25 AM
pacific northwest
pacific northwest
is the higher the # fatter or leaner?
Re: carb tuning ??? [Re: Stroker Scamp] #1220091
04/24/12 12:27 AM
04/24/12 12:27 AM
Higher AFR # (15.0)are leaner, lower is fatter,(12.0) just like altitude
Re: carb tuning ??? [Re: Cab_Burge] #1220092
04/24/12 12:31 AM
04/24/12 12:31 AM
PA
moparacer Offline
moparacer  Offline
PA
At 18-20 I bet that thing is sipping air somewhere.
Is this with open headers/collectors?
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: carb tuning ??? [Re: moparacer] #1220093
04/24/12 12:41 AM
04/24/12 12:41 AM
pacific northwest
pacific northwest
i am running bullet mufflers the sensors are in the extension in front of the muffs
Re: carb tuning ??? [Re: Stroker Scamp] #1220094
04/26/12 10:15 PM
04/26/12 10:15 PM
pacific northwest
pacific northwest
another dumb question but how much does the A/F change under load going down the track?
Re: carb tuning ??? [Re: Stroker Scamp] #1220095
04/27/12 12:01 AM
04/27/12 12:01 AM
It depends on the fuel system and carb., if it goes lean from the start line to the end of the run then look at what is casuing it. I've seen it caused by the fuel filter being to fine, to small of needles and seats, .110 versus .120 Not big enough pickup in the tank, not big enough fuel line to the front, not good enough fuel pump, fuel regulator too small and the list goes on
Re: carb tuning ??? [Re: Stroker Scamp] #1220096
04/27/12 12:10 AM
04/27/12 12:10 AM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i read it ritchens up under a load. i agree somewhat.
i run about 13 to 13.3 to 1 at the track.
setting up a street engine i use a vacume guage to see driving vacuum on the flat and then pull a hill to see what the vacuum drops to while pulling the hill. then get a power valve that is higher than that number or around that so it fattens it up pulling the hill.
after that i jet for 13.5 to 1 to 13.8 and want 13 or high 12 when the power valve is open on the primarys only for driving.
if the power valve is too low a number it will not open up and you will pe pulling a grade with good afr on the flat and go lean as you go open on the throttle.
remember when running a air cleaner that is real small you can actually start to build vacuum at high rpms and the power valve will close and relean out the engine and make you chase your ass. (this usually happens when a very low power valve number in in)
