I'm seeking some ideas from people with experience in clutches as I need to chose one about now.
Mega stupid level horsepower and torque .
Will wind boost back for use most of the time.
Will be driven regularly on the street.
526 hemi, supercharged, stick shift 6-speed (T56 magnum).
3.73 gears Detroit Locker in my Dana 60.
Guess the cars weight will be circa 3,900 lbs not sure (aluminum eng & gearbox is not too heavy).
I know the car Will be traction constrained so not "as concerned" about exploding the gearbox as it will not be fully loaded as if it had slicks or was on a chassis Dyno etc.
I know I won't be able to meet all the criteria but a few points would be nice:
1. Pedal effort not to great
2. Engagement not severe
3. Quiet (hahaa)
Now, I'll order a whole assembly but would like to hone in on + / - 's of the options:
4. Twin or triple disk?
5. Steel or Aluminium flywheel.
6. Ram or Spec or Other ???
Anyone's experiences or suggestions would be helpful, oh yeah also must be 130th flywheel to work with my bell & Mezziere starter. Hydraulic engagement.
Appreciate your ideas .
Cheers, Darren
